Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > NextD - Rave 450 and 90
NextD - Rave 450 and 90 CJY Rave 450 and 90 Helicopter Kit - ND-YR-K001
Old 04-26-2012, 05:00 PM   #1
brokenheli98
Default spindle shaft mod, dampner life increasers
Hey guys, I just wanted to share a really cool mod that will decrease the wear on your head dapners on your Raves. A guy I know had an issue with the head getting sloppy to quickly, but thanks to the innovators at Next D, there is a fix. What your gonna want to do is thicken up your spindle shaft between the dampners inside the the head. I found the distance to be about 22 mm, but you can measure yourself and make sure. Once I figured out the distance, its just a matter of measuring to the exact center of the shaft and then measuring, in my case, 11mm to either side of center, marking it and applying a few layers of duct tape with the ends of either side of the tape on your marks. Then put the shaft in the block, put your dampners on either side, work them in gently with a small flathead and press everthing nice and tight with the bolts. Then I mesured the gap between block and grip to make sure there nice and even and gave a good visual inspection, make sure everything moves nice and that was it. Also, obviously, always check for slop everywhere whenever possible. Thats how I did it, if anyone knows a better way or think I did something wrong, let me know. A boom strike with one of the helis can destroy the whole helicopter so be careful.http://www.helifreak.com/images/smilies/4_17_3.gif
brokenheli98 is offline        Reply With Quote
Old 04-26-2012, 07:31 PM   #2
superjosh
I did pretty much the same but I used shrink tubing instead of duct tape.
superjosh is offline        Reply With Quote
Old 06-16-2012, 04:15 PM   #3
Lee Taylor
I like the way you think... Just did mine the same way. Convenient, because the heat shrink slides right off the old spindle and onto a new one in the event of a mishap. No need to tape and remeasure each time...
CYJE - Field Rep
Ballistic 700/520 Ultimate/CC 160/Radix V2
ENV 105/MP7/Radix V2
Lee Taylor is offline        Reply With Quote
Old 06-16-2012, 09:17 PM   #4
BlakeMcBrayer
How many layers of heat shrink are you guys using? I like the way this sounds over duct tape.
Don't come off the throttles untill you see your God!!!
BlakeMcBrayer is offline        Reply With Quote
Old 06-17-2012, 08:23 PM   #5
Lee Taylor
I think I used 4, 22mm lengths of 3/8" tubing. It was just enough to actually fit through the passage in the block. I went one too many initially, and just stripped one layer off.
CYJE - Field Rep
Old 06-17-2012, 08:39 PM   #6
pctomlin
Hey Lee,
Thanks for the info on the shrink tubing, I will be sure to do this when I build my Ballistic.
Paul
Agile 5.5 - Quantum 4125-1100, Ice 100, Ikon FBL / Outrage 550 - HK4020-1390, Edge 120, iKon FBL
Rave Ballistic FSO - HKIII 4035-560, Ice2 HV160, iKon FBL / Protos Max V2 - MSH 4530-500, Edge HV160, Brain FBL
pctomlin is offline        Reply With Quote
Old 06-17-2012, 10:50 PM   #7
Lee Taylor
Originally Posted by pctomlin View Post
Hey Lee,
Not a problem. I'm actually just finishing my build now. Awesome build...great machine
CYJE - Field Rep
Old 06-20-2012, 06:24 PM   #8
Blade120
Great info guys, in the middle of my build now, looks like I'll have to take the head apart and mod it. Did you guys use any lithium grease on the spindle with the tape or heat shrink?
Sent from my DROID RAZR using Tapatalk 2
Trex 500 ESP(DFC) Ikon, Radix] [Goblin 700 CompBK, 4525, Ikon, Helix 695 ] [Rave ENV Nitro O.S 105-R,Ikon,Cyclone] Rave ENV Electric]Scorpion 4525,Ikon, Outrage, SAB [Goblin 500] Ikon Rails 516 ]Blade 180 CFX]Goblin 570 12S Xnova
Blade120 is offline        Reply With Quote
Old 06-24-2012, 01:55 AM   #9
Lee Taylor
No grease (w/ heat shrink)...slides off with an easy pull, if (when) the time comes.
CYJE - Field Rep
Old 07-06-2012, 02:22 PM   #10
kvnm27
Default addressing issue
Is Curtis or NextD going to address this and create something for purchase later?? Would beat having to measure, cut, heat shrink, duct tape etc!!
kvnm27 is offline        Reply With Quote
Old 08-11-2012, 11:15 AM   #11
jr_wiken
picīs please
jr_wiken is offline        Reply With Quote
Old 08-13-2012, 09:03 AM   #12
Geffect
From the posts ive read on various forums it would appear the "duct tape" mod is only necessary for those who are smack 3d pilots running high H/s ~ 2100 and higher..
Im not sure Curtis would consider it an issue, as having the "gap" in the center of the hub allows the heli to work well at lower h/s. Making the heli very versitile.
That being said, given that its called "Ballistic" perhaps a upgrade hub should be made available to those that want to run massive h/s and smack the #%$#$ out of their Ballistic..
Geffect is offline        Reply With Quote
