| Airtronics Radios Airtronics Radios Support |
Will Airtronics be making an S-Bus compatable reciever?
Getting ready to go flybarless and want to use CGY 750 and would rather not have to use the s-bus adapter.. |
Gues not....
The Capi - HF Support
You will never see 1 manufacture making their Tx compatible with other company rx.
SAB Heli Canada / RotorQuest/Compass Team KBDD Spreading capibara awareness since 2006 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
One can hope.....Maybe a FBL unit.....Wishfull thinking......
Terry Moore had mention on an episode of RC Today Show that there will be an S-bus like connection and Spek like sats at some point. The whole episode is a good listen but he mentions this around 44:30.
RC Today Show 002: Terry Moore from Team Airtronics
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. ):> Compass 7HV, Atom 500 "Some men just want to watch the world burn" |
#6 | |
#7 |
#8 |
#9 |
The OP asked if they will make an SBUS compatible rx so unless Airtronic plans to redo their PHY this isn't going to happen. Airtronics is more likely to come out with their OWN serial protocol not just use Futaba's.
#10 | |
If S-Bus were unique to Futaba, oither manufacturers peripherals wouldn't be able to work with it. TM |
#11 |
Other units decode the serial signal, there is a difference.
#12 |
Thanks Terry....
#13 |
#14 |
Plug a SATA device into a PCIe device and tell me how long it takes to get them to talk.
#15 |
#16 |
My point was that just because two devices are serial communication devices doesn't make them compatible. There are many FBL units out there that can decode the serial signal from other manufactures I have yet to see a rx that will encode a serial protocol from another manufacture. The OP's best option is to get a PWM to SBUS encoder.
#17 | |
TM |
#18 |
Cool, but I'll be as surprised to see it as actually seeing someone use an airtronics
#19 |
#20 |
Things are just getting started huh Terry.
