| Blade 400 Blade Helicopters (eFlite) 400 Helicopters |
I want to check this before i loctite it together. can someone check it out and see it i have everything correct/where to put it. i have to go buy some dampeners(didn't come with it).
Hello My Name Is Joe Blade mCP X BL - HP06V2 / Blade mCP X BL - Spin 16.3K / Blade 400 - DS760, 450MX / Trex 500ESP DFC - AR7200BX, 500MX / Trex 550e DFC - AR7200BX, 600MX Last edited by jabu32; 04-28-2012 at 04:42 PM.. |
okay figured where those cylinders go. between head and swash followers. check one off.
Hello My Name Is Joe Blade mCP X BL - HP06V2 / Blade mCP X BL - Spin 16.3K / Blade 400 - DS760, 450MX / Trex 500ESP DFC - AR7200BX, 500MX / Trex 550e DFC - AR7200BX, 600MX |
another prob. i need to replace the balls on the swash with ones from a 450 right?
which hole on the head block do you use to attach the main shaft. Top or Bottom?
okay are the two bearings that go in the swash follower suppose to have a washer between them i noticed that those washers i thought go between them are too big. should i buy some?
#6 |
what do you do for the swash locker arms? they are too big to attach to the swash balls.
#7 |
OK the bearings for the swash driver arms are flanged correct. They do not get a washer in between them. That washer in your pic by the driver arms probably goes at the end of the feathering shaft up against the outer thrust bearing. The large stepped washers while a bit different from my rjx head using rex pro feathering shaft, more than likely go between the damper and the bearing on main grip with step side towards bearing. You need to get some kbdd orange pro 450 dampers and a set of these.
http://helidirect.com/align-linkage-...ro-p-11147.hdx what swash do you have? You can't use stock 400 swash with the swash driver arms as the larger ball that needs to be put on the inner swash for the swash arms wont allow the swash arms to be snaped on the stock swash as there is no clearance. |
#8 |
what do i need to use stock swash? i saw someone saying you need to use genuine rjx arms.
#9 |
you cannot use the stock 400 swash with this set up. Other than the clearance problem when you try to snap the driver arms on the inner stock swash the stock swash is really not large enough outer diameter for proper geometry and will cause severe binding on the elevator ball link at the outer swash attachment ball. This has been documented so many times. You were asking what swash you needed just a short while back and were given advise by several members here.
#10 |
went to the LHS and saw the 450x swash lock arms. do you think this will work in place. also would the 450x linkages work?
#11 |
without some very very carefull measurments i could not tell you if the 450x swash driver arms will work on the hk/rjx clone head. As it looks in the photo they dont seem like they will be any where close to getting proper phasing (extremely important) with the rjx center hub . They are made for the blade center hub. Why not order a swash from cnc and get it over with. there are links to them here.
http://www.cnchelicopter.com/servlet/the-1413/CNC-450-SX-head/Detail you will need to use the antirotation pin from your stock swash. I have been told the 450x swash will work but I have not had one in hand so cannot confirm. Either way you are better off with the trex balls I linked to. Again the 450x swash drivers are designed for the e-flite center hub and look to be way off for use with the rjx clone center hub. Do not cut corners now or you may end up with a heli with unusable geometry. Ps considering the blade 450x swash in full cnc is 30 bucks I would not take the chance anyway's. I would order a proven swash from cncheli. They have another one available also. |
#12 |
how long does it take to get something shipped from them?
#13 |
About 4/5 days depending on a few variables. Assemble it as shown in these pics on post #39.
http://www.helifreak.com/showthread.php?t=366372&page=4 Scott also found another head at cnc heli that may work along with the one supplied in the thread link above. Hope this helps. I posted this earlier only because the head geometry looked correct and you can visibly see the raised center, which you MUST have. |
#14 | |
#15 |
is that the best swash? so i need this swash and the align balls?
#16 |
here is a 50 minute long video on assembling the hk clone rjx head. Boring but a lot of good info. Especialy the hk supplied trust washers between damper and grip are LOUSY. Best get the align pro 450 trust washers or helidirect has them on there site under fbl stuff. Watch it it may help ya out.
#17 |
ya ive been watching that vid. i bought the same 450pro feathering shaft that he is using. im using that and the supplied washer. im going to order that swash. so it is the best choice and will work 100%? will stock 450 dampeners work or do i need the kbdd?
#18 | |
PS. Don't forget the kbdd orange pro 450 dampers! Good luck with your build, Scott S |
#19 |
okay i ordered the 450 balls you listed, im ordering that swash, and im going to get some stock 450 dampeners. i will pick up some 450 links too.
#20 | |
http://helidirect.com/t-rex-450-pro-...cs-p-18972.hdx http://helidirect.com/kbdd-dampener-...ge-p-17161.hdx |
