Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450X
Blade 450X Blade 450X Helicopters Information and Help
Old 04-29-2012, 04:03 PM   #1
lovespicyfood
Default Best replacement mg servos?
Hi Everyone,
I have a used 450X arriving next week... What do you guys recommend for metal gear servos that will fit? I don't feel like replacing servos every time I crash!
Pete
lovespicyfood is offline        Reply With Quote
Old 04-29-2012, 05:38 PM   #2
Kumba
There seems to be three servos that regularly get mentioned for the Cyclics. They are (in no particular order):
1) Spektrum H3000
2) HiTech HS-5065MG
3) MKS DS92
The first two are in the $30 range. The last one is $50 or so. Now enter the endless amounts of responses where someone found it cheaper.
All seem to work great, weigh different amounts, perform differently, and have different features. I don't think anyone would recommend against any of them, but you will probably get lots of opinions on them.
I run the Spektrum H3000 servos and have no complains. They have better performance specs then the stockers, were cheaper then the HiTecs, my LHS had them on the shelf, and only added about 14g to the weight of the heli. A no brainer for me personally.
As far as the tail goes I am still running the stock servo with a 5.1v voltage regulator so I can run my cyclics at 6v. More torque and speed that way. About the only tail servo I'd recommend that is within the operating ballpark of the stocker is the MKS DS92i. It's about $90 if memory serves me right.
Someone on here was experimenting with some $15 generic MG servos. Don't know where that thread went or if he got them fitted but that's also an option. I believe they were analog instead of Digital which is a discussion for a different thread though.
Kumba is offline        Reply With Quote
Old 04-29-2012, 06:31 PM   #3
azezeil
Originally Posted by lovespicyfood View Post
Hi Everyone,
Pete
After I crashed pretty bad and stripped all my cyclic servo's I went with mks ds92's. They're $43 on amainhobbies. They fit fine, but are a little snug. You'll have to cut at the frame a little bit to fit the elevator. For some reason the servos have little nubs where the screw holes are so you gotta make room for those. I also replaced my tail servo with a spekrum 5030 but honestly, it's not really needed.
azezeil is offline        Reply With Quote
Old 04-29-2012, 06:43 PM   #4
lovespicyfood
Thanks a lot for the responses everyone! It gives me some good info to proceed...
Old 04-29-2012, 09:03 PM   #5
bshinn
The Spektrum H3000 and Savox to the best of my knowledge are the same servo as the Align DS410. They both are "on paper" identical to the Savox, which as I understand makes both the Align & Spektrum. The H3000 & DS 410 are slower than the 76T that came on the heli, but the Align DS 420 is a good match. Got mine at my LHS for $28.00 ea (swash & tail).
No experience with the Hi Tech, but plenty of people seem to like it. IMHO if you're looking @ MKS............you might want to be moving to a better airframe.
Don't get me wrong, I own several blade heli's, & like them all but I just can't justify spending 3/4 of what i spent on the whole heli on servo upgrades.
bshinn is offline        Reply With Quote
Old 04-29-2012, 09:35 PM   #6
benboy207
Here's how I see it. I can replace the gears in all 3 cyclic servos almost 17 times before I match the cost of the MKS servos. Not worth it to me, but I can understand why some might.
benboy207 is offline        Reply With Quote
Old 04-29-2012, 09:56 PM   #7
meatwad99si
Automotive technician - but really a rocket scientist
You can always transfer or sell the mks servos. If your gonna change your servos you might as well get the best right? Thats the way i see it. If your gonna get the mks ds92 get the ds92a+ they are for flybarless. And the same price i believe.
meatwad99si is offline        Reply With Quote
Old 04-30-2012, 12:12 AM   #8
Sambuka
After 17 gear set replacements I don't think you'll be enjoying the gear set change as much as you did the first time ;-)
I'm putting in 5065mg's but wish I went with the MKS. Oh well hopefully they hold up well enough.
Sambuka is offline        Reply With Quote
Old 04-30-2012, 12:26 AM   #9
lovespicyfood
The Align DS420s seem like a good value, $27.99 a piece and FAST.
Old 04-30-2012, 12:58 AM   #10
Daniel880516
Mks Ds92A
Team RotorQuest / SAB Heli Canada
Goblin 770
Xxtreme 800, Xxtreme 700
DX18
Daniel880516 is online now        Reply With Quote
Old 04-30-2012, 05:33 AM   #11
bshinn
The 420 is their tail servo. Might not be torquey enough for the swash, use the 410, same price.
Old 04-30-2012, 05:41 AM   #12
thomascoleman
my cylic servos stripped when i moved the blades the wrong way by mistake!
as a direct replacment i ordered another DS76 Digital Servo EFLRDS76
What would be a good Savox replacment MG? As my local Hobby shop stocks these.
Spektrum DX18 | T-Rex 500 DFC AR7200BX | T-Rex 450 Pro DFC AR7200BX 3S | T-Rex 450 Pro DFC AR7200BX 6S | Align 250 DFC 3GX | Goblin 630 AR7200BX
thomascoleman is offline        Reply With Quote
Old 04-30-2012, 11:09 AM   #13
Jhook
I also like Savox servos, I have the SH-0257MG and they work great!
Jhook is offline        Reply With Quote
Old 04-30-2012, 11:23 AM   #14
Maxthepersonz
DS410's work good. What servo horns do you guys use for aluminum ones on the Align/Savox servo's.
Maxthepersonz is offline        Reply With Quote
Old 04-30-2012, 01:57 PM   #15
bradharvy
I already bought my 5065's. I got a quark coming as well. What would the suggested tail servo b? They didn't have the 5084 I was going for however someone stated it was a little heay but solid. I would still go with it, I like hitec on all my planes but helis are different sooo... Any other good tail servo to go with my quark and hitec cyclics? Or just grab a 5084 online?
Happy flying
....Brad
BLADE 450Xx2,300X ,130X NEVER! McPX BRL, 120DO2s, McPX, Stryker , Edge 540qq,UMX BEASt, Crak Yakx2,
YAK 55M 35CC,A.W. PRO 260 20CC,3dhs 330sc 57inch, extreme flight 300 60 inch, ALL ON MY JR9503
bradharvy is offline        Reply With Quote
Old 04-30-2012, 02:03 PM   #16
ahahn
Not sure what you plan on using a Quark for, surely not for the 450X---right??
ahahn is offline        Reply With Quote
Old 04-30-2012, 02:06 PM   #17
bradharvy
Yea.. I thought I'd throuh it on top the 7200bx...
I'm talking 3d, MY BAD! .. Anyways... Any thoughts? lol.
Happy flying
....Brad
Old 04-30-2012, 02:08 PM   #18
bradharvy
been jumping back and forth and seems servo talk is in both! I got confused , It's all good!
Happy flying
....Brad
Old 04-30-2012, 04:39 PM   #19
Flying_Amp
Another vote for the Savox Sh-0257 MG's... already with stood a blade strike that resulted in a bent feathering shaft, after the numpty pilot mixed up the Ail and pitch connections.
so they are tough little servo's
MCPX V2
Tarot 450 pro V2 FBL Zyx gyro
Blade 450X FBL
retired to the black bin bag!!
Flying_Amp is offline        Reply With Quote
Old 04-30-2012, 07:15 PM   #20
InFocus
I was of the mind to just buy replacement gear sets for the DS76.. I had replaced the gear sets several times with success.. But, once the servo failed while the gear sets were good. It became 'weak', I thought it was ok, but my elevator servo stuck while doing back flips... arg..
Anyway, so rather than buy a replacement DS76, I got 3 Spektrum H3000's.
They dropped right in with no frame modifications needed. You do need to modify the FBL setting to reverse them.
I flew them this weekend and they worked just fine, and I did not have to modify my FBL gain settings.
Blade 300X, mCPX, FPV Raptor, UM F-27q Stryker, UM P51 Mustang, F4F Wildcat, DX7s.
InFocus is offline        Reply With Quote
