Old 07-21-2007, 08:58 PM   #1
melderor
Default Adjusting Piro Rate
What is the correct way to increase the piro rate with a GY611. Do you increase the rudder travel in the transmitter and leave the travel end points in the gyro alone ? My travel adjustment in the transmitter is set at 100% right now but the heli piros fairly slow.
melderor is offline        Reply With Quote
Old 07-21-2007, 10:53 PM   #2
Fox222
Check this out it tells pretty much the whole story.
http://www.helifreak.com/viewtopic.php?t=40823
Fox222 is offline        Reply With Quote
Old 07-22-2007, 12:25 AM   #3
shauntot
adjust atv in radio to 150%, leave the 611 as it is. ballistic piro rate if you have it set up as per finless' vids
shauntot is offline        Reply With Quote
Old 07-22-2007, 02:42 AM   #4
Mercuriell
Default Re: Adjusting Piro Rate
In short YES. I'd suggest increasting the Tx endpoints 10% at a time till you get the feel of the piro rate you're comfortable with. As you state the gyro end points have nothing to do with piro rate and the Tx endpoints have nothing to do with gyro limits - confusing huh ?
John
Mercuriell is online now        Reply With Quote
Old 07-22-2007, 06:38 AM   #5
melderor
Thank you to everyone !
