| Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum |
Where can I find it in stock in the US? I've been looking for a while now, any help is appreciated, thanks.
T-REX 500 (a.k.a. try everything I learn on Phoenix) T-REX 700E (Pride and Joy) Avant eAurora (Sexiest heli I've ever seen) Outrage Fusion 50 FBL 6S (my multipurpose baby) |
It is quite easy to do it your self..
You can trim the boom and trim the tt shaft and drill a new hole for the screw.
Outrage 550, Goblin 630, 700, warp 360, Dual BL Mcpx, 130x **When you start to be in complete control reflexes are not a requirement.** |
How much am I cutting off of the boom and tt? I figured it wasn't that hard but I was trying to avoid doing it myself because I just don't trust myself with it.
Depending on your flying you can just fly the stock boom with 6s/550mm blades. I did and it was fine. Now if you are into hard 3D and lots of piro moves you will want to shorten the boom.
It's not just a hobby... it's a lifestyle! Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo Pete Team Outrage. |
I am into hard 3d and piro moves and I keep it at stock length still with 6s and have no issues I can perceive..
#6 |
just look at the fusion 50 boom length and the outrage 550 boom length (on heli direct specs) and the difference is what you cut off.. I have never done it as I fly with the longer boom fine.
#7 |
OK, thanks fellas. I'll give it a shot. I can always buy another one if I mess it up.
#8 |
I cut 85mm out of my torque tube and boom.
Current Fleet: TRex-700/500/450/250 Vbar, Logo 600SE/600/500 VBar, Outrage Fusion 50/G5 VBar/FB, Blade mCPx x 2 |
#9 |
If you do not mind the color - this one is actually in stock. I tried it out and also the standard tail boom length worked too with 550 mm blades the shorter tail seems more locked in to me.
http://helidirect.com/sa00091a-outra...it-p-25673.hdx |
