| 450 PRO Class Electric Helicopters 450 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Anybody have any experience with the DFC head install. I swapped an RJX head for the DFC head same exact Beastx settings and it wobbles and vibrates like hell. I turned the gain down substantially but no help. I installed the two shims the come with the dampers kit. I also noticed the out of the box dampers sort of loose around the shaft. I upped the head speed during the maiden still no good. Any thoughts?
The bitterness of poor quality, lingers long after the cheap price is forgotten. Buy the best and only cry once! |
my heli has not been the same since I installed the dfc head I am having the same problems but have not had a chance to mess with it that much
-Henseleit TDR, CC ice 120, Torq9188/9180, 750mx,Thor lipos, Ikon fbl, Gryphon Quasar bec -mini protos hobbywing 40 esc, msh1300kv, mks 92a cyclic, mks 8910a tail, stretched edge 353mm main blades, brain flb, 1300mah 6s lipos how high does it go |
check the tightness of your blade grips
SAB Goblin 500
MA Whiplash Electric - 14S To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Hello,
I also want a dfc on my 450, but when I read these posts I begin to hesitate. what's wrong people, is there something wrong during installation or the parts are not good? Who flies currently the dfc head, and has no problems with it? who can give good advice Danny
We Men Need a Second Hobby, Besides Women To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Futaba T8FG T-Rex 550 & 450 DFC BeastX V3 Logo 600se VBar 5.3 pro Kontronik www.modelhelicopter-review.nl |
I swapped out my Tarot FBL head for the DFC head Saturday. No issues at all, much smoother than the Tarot, easier to setup 0 pitch, etc.
Running BeastX on mine as well, full specs in sig.
[ 300x | Robird ] [ Protôs | Stretched, Low Head, BeastX, YGE60, HS-5245MG, BLS980, Scorpion 880kv ] [ Goblin 500 | SK540, Talon90, DS515M, BLS251, Quantum 4020-1200 ] [ Gaui X5 12S | Ikon, HW70HV, DS610, BLS251, Quantum 4125-560 ] |
#6 |
What is your heli setup stock servo esc 2200 3s lipo?
#7 |
Hobbywing 40A ESC
CY NextD-6 Motor (4400kv) 11t pinion Turnigy 3S 2200mAh 40C batteries Savox SH-0255MG cyclic
#8 |
Thanks Jaofos,
Good to hear that you have no problems with the dfc can you tell me what your head speed is? Danny
#9 | ||
(calculated for 100% throttle curve) Hover RPM at beginning of flight: 3802 Hover RPM at middle of flight: 3502 Hover RPM at end of flight: 3380 From this doc: http://innov8tivedesigns.com/Softwar...HeliMotors.pdf Quote:
#10 |
Does your head appear to teeter on the shaft? Did you use the shims inside the grips behind the inner thrust bearing race?
#11 |
No, the head is rock solid, no play in the grips or the fitting on the shaft.
I used spacers in the grips, exactly as the instructions say and the spacers against the dampers that came in the DFC kit.
#12 |
Jaofos, what do you think, my 450 pro V2 is stock with a Beastx onboard.
Main drive gear 150T Motor 450MX Motor Pinion 15T Stock ESC (bl 35X Align) Zippy 3S 2200mAh 45C Can I use the new dfc rotor head without problems ![]()
#13 | |
#14 |
#15 |
I think I'm just going to try the dfc, maybe I'm lucky, and it works well for me also
#16 |
Do you have to redo the setup of the BeastX, and then, in particular, the six degrees blue
#17 |
I didn't redo any part of the beastx setup after installing the DFC head. All I had to do was lengthen the servo to swash linkages.
- 6S TREX 450 Pro FBL - µBeast, MKS DS95 and 8910A+, DFC Head, CC ICE Lite 50, 450MX 1700kv - mCPX - Spektrum DX7 |
#18 |
I went through the BeastX menu J and had blue at 6 degrees. I also double checked my collective range (K).
#19 |
thanks for the info guys, I check the BeastX settings J and K after I installed the dfc just to be save
#20 | |
send it back for replacement...it should not be loose chris
trex 450 pro-fbl-scorpion 2221-8-custom motor mount-beastx-tarot head-beam e4 swash trex 550e-castle 100 ice-bec pro-alloy tail control arm- 550mm blades-beastx-compass 6hv head-2mm side frames futaba T8FG--R606FS/R617FS |
