Old 05-01-2012, 05:09 PM   #1
aForcefulThrust
Default Best way to remove stripped screws from 450 pro frame?
Okay I can drill them but I fear I will ruin the threads where the screw is screwed in to. Any tricks to this? Thanks!
(Mine are stripped on the tail boom mount)
Sent from my DROID BIONIC using Tapatalk
aForcefulThrust is offline        Reply With Quote
Old 05-01-2012, 05:15 PM   #2
ChrisH
Use a dremel (or other rotary cutoff tool) to cut a notch in the screw head, then use a flat head screwdriver to unscrew it.
ChrisH is offline        Reply With Quote
Old 05-01-2012, 05:46 PM   #3
Andrew_ZA
+1
Andrew_ZA is offline        Reply With Quote
Old 05-01-2012, 06:11 PM   #4
heliglenn71
+1 works every time.
heliglenn71 is offline        Reply With Quote
Old 05-01-2012, 08:32 PM   #5
Lunchbox
One small suggestion. You might want to look at getting high quality hex tools like MIP or Hudy. They're made of super strong steel and fit a lot better. If you take the time to seat them properly, you'll never strip another screw.
Blade 130X, Blade Nano CPX
Edge 540T, Mini Funtana X, UMX Sbach 342 3D
Lunchbox is offline        Reply With Quote
Old 05-01-2012, 11:19 PM   #6
fuzzyllamma
Is there a place to buy a set of mip's or hudy hexdrivers? I can only find 1 at a time for the mips...
fuzzyllamma is offline        Reply With Quote
Old 05-01-2012, 11:23 PM   #7
Indydrt
i removed 9 screws tonight on a used 450 pro i bought.. i used the dremel slice screwdriver method..works well. also i used and sometimes its works great if deep enough a screw extractor from a auto parts place or home depot.. etc that can save alot of time also fit in areas where dremel cant cut the screw.
Always thanks for the help much appreciated makes the hobby alot easier and enjoyablesince i began flying in dec.2011
Indydrt is offline        Reply With Quote
Old 05-01-2012, 11:36 PM   #8
Fredo0709
Anyone have a good idea about how to remove a sheared screw sitting flush with the surface? The screw is about 1/16" in diameter.
Sent from my ThinkPad Tablet using Tapatalk 2
Align TRex 600E Pro, 3GX v3.1; Align TRex 450 Pro DFC, 3GX v3.1; Align TRex 250 Pro DFC, 3GX v3.1, Blade mCPX BL
Fredo0709 is offline        Reply With Quote
Old 05-02-2012, 01:09 AM   #9
Indydrt
see if you can remove ..i'm assuming the heli frame the screw is flush with??
if so then remove as much as you can to get to some of the threads and then try a needle nose pliers.. to work it free kinda pain in ass but)
other i dea was try drill it .... then use a screw extractor tiny one..good luck
Old 05-02-2012, 04:51 AM   #10
chrismechanic
if its in metal..heat it up real hot and use a sharp pointed steel tool to spin out the thread.
while it is still hot push the thread around with the point of the tool.
chris
warp 360-ds92-ds525m-polaris bec-beastx-edge 50 lite-yummy
Synergy E5-castle 100 ice-bec pro-beastx.
futaba T8FG--R606FS/R617FS
chrismechanic is offline        Reply With Quote
Old 05-03-2012, 01:31 AM   #11
Lunchbox
I use MIPs. They only come one by one. They're expensive but definitely worth the money.
Old 05-03-2012, 03:38 AM   #12
Chazzypuk
Be careful using a Dremel. You will need a very steady hand or some sort of drilling mount to prevent cutting too wider cut in your screw. Due to the high cutting power of the Dremel it chews though the screws like a knife through butter! If the cut is too wide your flat head screw driver will not fit properly and then you could be in trouble as there is not enough metal left to try again.
As my screw was a surface screw and not recessed I used a small hack saw. It was easier to be honest and less likely to damage your heli and you have more control and it gives a nicer cut (But maybe I'm just bad with a Dremel!).
I buggered one of my screws using the Dremel and I thought I was up **** creek without a paddle as I couldn't get my screw out! :-( In the end a good technique that worked for me was to solder an old Allen key to it. This worked so well and the screw just came straight off. Make sure you tin the bolt head and the Allen key separately first to get a good bond. Once you have done this put them together and apply more solder (but not too much you have a molten lake!) allow to cool fully before trying. This method also has the advantage it heats the screw, thereby unlocking the thread lock you have put on and hence it requires less torque to remove it.
Hope this helps,
Chaz.
Chazzypuk is offline        Reply With Quote
Old 05-03-2012, 09:00 AM   #13
scoio
Just happened to me yesterday.Stripped the front TT gears and had to remove the tail block.
I lcoktite the screws on building phase and was impossible to remove them...all stripped! (quality of Align screws anyway sucks).I used a dremel with a cutting wheel...carefully I managed to get them all out.I got used to do this to Align helis..
Chris
Team iKon
GAUI X7 F, Scorpion 4525-520,CC Edge 160HV, iKon FBL,Servoking HV,
GAUI X3L, Gaui 1400Kv, CC Edge 50, iKon FBL, KST V3,
GOBLIN 500S, Quantum 1200Kv,HW 100V3,iKon2 FBL, KST HV
GOBLIN 700 C Scorpion 4525-520,HW160HV,BLS815HV,iKon2BT
scoio is offline        Reply With Quote
Old 05-04-2012, 10:30 AM   #14
chan
It happened yesterday to me.
I used small hand file.
Make two opposite side flat of that screw.
After that grap and unscrew it with middle size pliers(not small one).
With this, I successfully removed that bad screw
chan is offline        Reply With Quote
Old 11-25-2012, 12:28 AM   #15
Avidflyer
I just went through the used Heli loctite nightmare. Here's todays tip... If when you tighten the screw loctite squirts out from under the head all over the frame. You used too much!!!! Good lord what a mess. I used one of those really thin cut off wheels on a slow speed on my dremel. Worked like a charm! Use a long handled screwdriver with a thin tip for more leverage. Thanks for saving the day once again HF!
Blade 130X
Align 450 ProV2 AR7200BX
Raptor 50 V2 OS50 Hyper FBed and Non digital servos!
Align 700N LE BeastX
Avidflyer is offline        Reply With Quote
Old 11-25-2012, 09:48 AM   #16
Danny Dugger
Left hand twist drill bit! It should come right out while you're drilling it. Plus the drilling heats up the screw so it helps break down any loc-tite that is holding it.
Danny Dugger is offline        Reply With Quote
