Go Back   HeliFreak > R/C Helicopter Support > NextD - Rave 450 and 90
NextD - Rave 450 and 90 CJY Rave 450 and 90 Helicopter Kit - ND-YR-K001
Old 05-01-2012, 06:48 PM   #1
rcbirk21
Default rave 450 3s 350mm
can i run 350mm on the 3s setup? nextd-6 3s motor, nice 3s spyder packs, either align esc or castle ice50 (can go to the 75 if necessary as i havnt gotten an esc yet but have the align laying around)
rcbirk21 is offline        Reply With Quote
Old 05-02-2012, 06:42 AM   #2
jay hall
I am running the 3s setup with 350mm blades, align esc, 450mx motor, turning 2800 on the head and it flies super nice. It's not the fastest setup in the world, but i like it. Butter smooth.
Jay Hall
Rave ENV, Vbar, 8717's OS91 Hzr, MP-7.
Rave Ballistic, vbar, Scorpion 130, Scorpion 4525- 520. Radix 690v2.
Rave ENV, Vbar, ATG, Radix 710v2, OS105.
jay hall is offline        Reply With Quote
Old 05-04-2012, 10:18 AM   #3
Ejeremy
I'm running 350mm nextd-6 3s tp 65c 2250 12t pinion koby 40....just awesome! Hang time is crasy for a 450!!
Jeremy
Rave 450 FBL
Rave Env Nitro FBL
Ejeremy is offline        Reply With Quote
Old 05-04-2012, 04:41 PM   #4
helienv
rave with 350s is the way to go! but works better on 4s 3s still rocks
Team Curtis Youngblood Enterprises
Team RREmodels
helienv is offline        Reply With Quote
Old 05-04-2012, 09:36 PM   #5
MHN777
Have you tried a lighter 4S lipo pack?
Helis- Hummingbird FP (sold)/ MS Hornet 2 (micro) ( RIP)/ Swift 16 (Retired) /Protos 500 (Sold)/Pheonixtech TT360 Beast X V3
Planes:-Dualsky Extra 330s/Parkzone Ultra Micro/Dreamflight Alula /Super Topsky 2.0 (In the build)
MHN777 is offline        Reply With Quote
Old 05-05-2012, 05:22 PM   #6
rcbirk21
well i bought a used setup from a guy with the -6 motor, 3 pairs of 350mm blades, and i already have some 3s2200 packs. just wanted to make sure i wont burn anything up
Old 05-08-2012, 01:08 AM   #7
MHN777
Get a pitch gauge and a tachometer.
Use "Dark Horse Calculator" to work out the headspeed and amp draws on the advanced calculator system.
You should be fine if the lipos are 45C continuous...
Old 05-08-2012, 08:42 PM   #8
LaDon
We are running a 3s system with the 350 blades. I have the govorner set up at 3200 with the stock nextd 6 motor. We are running a 65c 2250 3s pack and works great. I am not going to a 4s and putting the extra weight on it as it is just a riot to fly this way. We also are running a flybarless head with a vbar and that really opened things up. If you are still running the flybar I would switch that first it made a whole new machine that was not only smoother but more powerfull and more fun to fly.
LaDon is offline        Reply With Quote
Old 05-08-2012, 08:52 PM   #9
rcbirk21
i havnt flown it yet, but ive got a flybarless setup with a micro beast, spyder 3s2200 packs, and the radix 350mm blades. just got my esc (castle ice 50) and new cyclic servos should be here tomorrow (mks ds92a+). im itching to fly this bad boy
Old 05-13-2012, 09:47 PM   #10
LaDon
I have no experience with the beastx but if that thing works well you will love the setup. We are using the governor on the cc we have and that makes a world of difference on how it flies
Old 05-30-2012, 05:16 AM   #11
R3L72
Talking NextD Scorpion 8
I purchased a CY Flybarless 3S Rave 450 Kit the other day (will be #3; other two are FB) and want to keep all my Rave's 3S for now.
Question: Swinging the 350's powering off of 3S 2200mAh 30C Lipo's, do I want the NextD Scorpion 8?
I would like to make them all different and I'm still researching the Pro's/Con's of other pilots Rave Setup's. Oh...and 14t or 15t Pinion? I'm also Sports Flying right now and still working on my flying skills.
CY NextD Rave 3D, MSH Mini Prôtos (6S) Stretch, Prôtos 500 Stretched
Blade 450X, 300X, 130X, mCPX, Nano, DX6i, DX8
Align Trex 450 V2 Pro DFC, & too many others to list...
...living the Hobby 4+ minutes at a time
R3L72 is offline        Reply With Quote
Old 05-30-2012, 10:32 AM   #12
Ejeremy
Default 3s 350mm
NextD Scorpion -6 with a 12t or 13t. It really depends on what HS you wanna run.
Jeremy
Rave 450 FBL
Rave Env Nitro FBL
Old 05-30-2012, 12:20 PM   #13
R3L72
Post 3S 350mm
Hmmm, that's definitely a good question but I'm pretty comfortable with high headspeeds; at least with my experience with ultra micro Walkera's running Turbo Ace out-runner motors...the higher the headspeed, the more stability and pop/response.
With the Rave 3D Scorpion 6, 350mm, I'm gonna guess between 2900 and 3000; course, without taxing the motor, Lipo, and electronic's. I'll personally have to test it out to see what works for me but I definitely want to keep it in the safe zone as far as the tail gears go.
Old 05-30-2012, 02:26 PM   #14
Ejeremy
I'm running the -6 with a koby esc 12t 2900-3000 HS. Stay under 3200 and you'll be golden!
Jeremy
Rave 450 FBL
Rave Env Nitro FBL
Old 05-31-2012, 07:53 PM   #15
lolramen
Similar post as the other thread, but I use a -6, ice50, 13t, 3s 55c packs, and run 3200. I found that at 2900 or below, I lost quite a bit of tail authority in hard 3D. As long as you run below 11 degrees of pitch or so, you won't run out of gov headroom.
Synergy E5s - BeastX - 6HV motor - ICE120 HV2 - DS 610
Trex 600 Nitro - BeastX - TracX - YS 56SR - B320 - DS 610
lolramen is offline        Reply With Quote
