Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 425
Hurricane 425 Discussion and support of the Gaui Hurricane 425
Old 05-03-2012, 02:46 AM   #1
wakeup
Default 425 build congig for comments
Hi again to everybody,
I am really glad for such a good informative forum and such responsive peoples.
So, my bird is already come and waiting for the assembling.
I still did not purchase anything yet because I want to discuss it with you guys first.
Planning config and part list:
Basic kit Gaui Hurricane 425 (in future extend to 550)
Motor: Hyperion HP-HS3026-1210
Gyro: Spartan Quark MEMS AVCS Gyro V2.02 (what is the difference between black, clear and gold edition?)
ESC: Castle Creations Phoenix ICE 75
BEC: Built in 5A
Servo's:
- Cyclic: Hyperion HP-DS20-FMD
- Tail: Hyperion HP-DS20x-GCD + tail servo boom mounting set
Batteries: 2x3Sx2650mah
Transmitter and receiver: Spectrum DX6i combo with receiver AR6200
http://www.amainhobbies.com/product_...iver-No-Servos
Blades: wooden for the beginning and for the beginners
Any comments are welcome.
ps I am the beginner in heli fly. I am practicing right now with Blade MCPX and simulator.
Thanks guys for the support.
wakeup is offline        Reply With Quote
Old 05-03-2012, 05:51 PM   #2
sp00fman
a pinion
Servo mounting plates, for looks and ease of install.
Trex600 landing skids and struts (redrill of holes needed, but easy)
PC connection for ESC?
20T OWB, to be on the safe side. (Some reported problems with the 19T, and i suspect a failure on my Hurri425 also)
Push rod adjuster http://www.heliflightcenter.com/2046...d_p/204661.htm
Further than that...have fun building!
FBL clone 250 + 450's - with CX-3X1000
FBL GAUI Hurricane 425 EP with ZYX-s -=- GAUI Hurricane 520mm - bell/hiller mixed paddled stabilization
The more money you have up in the air, the less you love it...
sp00fman is online now        Reply With Quote
Old 05-03-2012, 07:47 PM   #3
tolenca
Hi p00fman, would you please to tell me what is the failure with the 19T ? I am about to build my first CP gaui and my setup will be pretty much the same as wakeup. What use is the Push rod adjuster?
Thanks in advance
Tolenca
tolenca is offline        Reply With Quote
Old 05-04-2012, 06:58 AM   #4
wakeup
Hi to all,
to sp00fman
Pinion
agree, still under discussion, with a such motor I am planning to have 16T with 1210kV motor = 16/50/19/61 = 2750RPM
Could you please explain that, or better link reference.
Yes, I heard about Trex600 landing skids that it is really nice and strong but what about struts?
Yep, I'll check it.
Please explain the issue.
What is the purpose of this thing?
to tolenca
could you please listed your gaui config. I just want to check the difference.
thanks guys
Old 05-04-2012, 08:15 AM   #5
tolenca
Sure....
Motor: Turnigy 500 H3126 1300KV
Pinion: 14T (Front G:50 OWB: 19T Rear G:61)
Gyro: Spartan Quark
BEC: Built in 5A
Servo's:
Batteries: Nano-tech 1x6Sx2650mah 35C
Transmitter and receiver: Hitec Aurora 9x and Optima 7
Blades: 430mm Carbon Fiber Blades
Like Wakeup says… Any comments are welcome.
Old 05-04-2012, 08:37 AM   #6
wakeup
Yep, looks the same except few things.
Do you know the difference about Spartan Quark modifications: Black, transparent, gold? Only the case?
One more question. As I still did not decided, where (shop) are you planning to purchase whole the listed things?
I thought that the main blades (wooden) are included in the kit, but it is not.
Old 05-04-2012, 09:37 AM   #7
tolenca
So far as I know the only difference is the case, however I think the metal case help handle better the statics and crash.
You are right no blades with basic kit. I will buy the blades in hobbycity
Old 05-04-2012, 01:54 PM   #8
wakeup
tolenca
hobbycity and hobbyking is it the same shop? cause I can not open any hobbycity webpage.
what is your choice for the spartan quark? Just a simple one black box? I thinking to buy the black one.
What about the servos and other stuff? Did you buy it already? I am just trying to find a good place to order it and still thinking.
Old 05-04-2012, 04:40 PM   #9
sp00fman
The mounting plates are like washers on the screw to clamp down the servo to the heli.
It can be used with or without the rubber grommets on the servo (i think). Dont place the brass tubes in the rubber grommets, as the Gaui screws are to fat to fit in them.
The OWB seems to have a tendency to slip or lock up, and the 19T is prone to crack open (evident by a few posts, but i think the majority just fly with them anyhow)
I suspect my OWB started to slip so i lost power to the rotor and crashed.
The rod adjuster is used after you cut up the stock pushrod for the tail control to make a shorter, straight pushrod with threading on both ends.
Lol, i was trying not to place all the hobbyking links, I think you have have to decide for yourself where to buy parts. Most parts i posted are found with the first hit on Google.... Oh well, here goes. (HK should start paying me by now)
http://www.hobbyking.com/hobbyking/s...dproduct=11714
http://www.hobbyking.com/hobbyking/s...dproduct=11713
http://www.hobbyking.com/hobbyking/s...dproduct=10696
http://www.hobbyking.com/hobbyking/s...dproduct=12297
I have ordered this new motor to test out. has not arrived yet.
http://www.hobbyking.com/hobbyking/s...dproduct=22400
I got my Hyperion servos from this nice japanese webshop. Quick shipping.
If you can buy them locally you dont get trouble with customs. your own decision.
http://www.aircraft-world.com/shopdi...radio+-+SERVOS
Old 05-05-2012, 03:00 AM   #10
stark
wakeup,
at 2700 RPM, you might be better off with carbon blades than woodies. I don't have experience with woodies, but that is what I have read on the forums.
For Castle ESC, you can get the Castle link adapter for free. When you buy the ESC you get a coupon code which you can use here
http://www.castlecreations.com/products/clink.html
You can use any standard mini-USB cable with that adapter so you don't need to buy the USB cable that they provide.
Also I'm still using 19T OWB, but I have very few flights on my heli, so it may not be solid proof that it is flawless.
cheers,
-roger
Compass Atom 500 FBL, GAUI hurricane 425EP
stark is offline        Reply With Quote
Old 05-05-2012, 02:06 PM   #11
tolenca
Wakeup:
Yep they both are the same. I am going use the black plastic edition. I still need to buy servos, motor and esc. Hobbyking will be the principal source for parts.
Tolenca
Old 05-10-2012, 06:44 AM   #12
wakeup
Hi Guys,
Sorry for the late answer, was celebrating the holidays far from home.
Thanks a lot for the explanations even for the stupid questions from myself and really easy things.
This is my first experience with assembling and purchasing so much spare parts from different stores. Any answers are very welcome, especially where it is possible to receive some additional redeem or free additional useful things because of main purchase. You never know where is what.
By the way, I found some interesting offer from Spartan right now:
http://www.spartanrc.com/store/produ...1&cat=1&page=1
Do you think it is a really good deal and I have to hurry up and purchase?
Old 05-11-2012, 04:37 AM   #13
stark
awesome offer on the quark. I would blindly buy it.
-roger
