| Scale Helicopters Discussions About Scale Helis, compatibility and and projects |
Well, here I go again! I am looking at the possibility of using a Hacker motor for my AH-1S Cobra (Trex 600 Mechanics) and so far I can't quite understand the tech specs of their motors to determine if it would work for me. Given that I plan to run a 12S setup, has anyone else in the scale community run Hacker motors in a 600 setup (or 700) and what might be the pros and cons?
Horndogg AKA HD-1080P AMA# 964712 Trex 600E PRO FBL (3GX), Scale AH-1 Cobra (under development), F550 Hex copter with GPS and strobes To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#2 | |
I have 5 Hyperion motors on my scale helis and none of them have failed yet.. just saying |
I was looking at the Scorpion line but the one thing that kinda gave me pause was the whole lubing bearings every 5 flights.... I hear they are very powerful and reliable but there are plenty of helis running other motors that last just as long that don't need that much maintenance. For a scale application (especially in THIS narrow fuse) it would be a nightmare getting it in and out just to lube bearings and check the motor. And due to the weight involved, I was even considering a 700 sized motor... I have a ICE 120HV and plan to run 12S though so I am searching for a very efficient yet powerful motor... I shouldn't need more than 2000RPM on a 2-blade head flying non 3-D but it's good to know the power is there should you need it!
Consider an Xera motor - very well built, no oiling required and seem very efficient. I run one in my Vario Long Ranger, and have just fitted (but not yet flown) one in my 4 blade 600 - both are 4030/3Y - 470kV.
A bit more costly than a Scorpion, but no worries with oiling. Colin
Vario Long Ranger 700e Seahawk 600 - work in progress Atom 500 Trex 450 SA hybrid |
#5 | |
Nice to know Andy, I will be keeping a eye on those for future reference.... |
#6 |
Flew the Xera today, and it ran about 8°C (14°F) cooler than the Scorpion 4025-550 and perhaps a few Watts less for similar flying - I put back about 80-100mAh less after two similar 6 minute flights.
It was also noticeably quieter than the Scorpion. I just checked the vibration logs from my Skookum, and the Scorpion was giving me a vibe of 2.3 units at motor speed (more than double any other frequency), whereas the Xera gives me a vibe of 0.7 at motor speed, which is basically the same as my tail speed vibe, so it is contributing a lot less to the overall vibe reading. Colin
#7 |
Going to check one out now and see what specs I can get on their setups..
#8 |
I got a Hacker A40 10L 8 Pole ET, CC ICE Lite, gonna try the series 3S hook up. This is powering a 30 size Airwolf. I just finished the motor mount mod today. From what I read and calculated from several sources the motor will give me HS around 2100 rpm. I went w/Hacker because of maintenance, price, and reviews.
I'm fairly new to a lot of the tech issues in this hobby. So I rely on forums for the most part, until I can get to the field. So I do a lot of reading and printing. What is it about the specs for Hacker that has you stumped? |
#9 | |
#10 | |
#11 |
I have got a set of Chaos 600 mechanics, which is essentially identical to the Trex 600 frames I think.
http://www.scaleflying.com/Carbon-Fi...mm_p_1679.html I have probably 10-15mm between my bottom plate and the bottom of my 4030 motor. The 4030 is definitely longer than the 4025-550 it replaced, but still plenty of space. Colin
#12 | |
#13 |
OK. The 4030 is 61mm long, so that may not work. You can't fit spacers under the frames to lift it up ? 43mm doesn't sound like a lot for a 600 sized motor.
Colin
#14 |
I will have to use spacers to get the main gear to rotate within the cutouts of the side missle armament pod fins on the Cobra. But because it requires specific placement I can't go up or down any more in height on the frame itself. SO... looks like my only alternative is to trim out the bottom of the Cobra for clearence or use a shorter hight motor and lower cell count (10S VERSUS 12S). Would love to have a Xera in there or Hacker but it will be too long. MAYBE I can flip the motor upside down and set it up that way. Will have to check the side frame clearance (METAL!!!).... One way or another IT WILL FLY!!!
#15 |
HornDog,
I had to cut the base of the frame to fit the motor. I am using a Turnigy Typhoon 1100kv motor. Head speed is the lowest I can go. But I forgot what it is!!!! Here are some new pics with shark teeth on the front. I can see it easier from the distance. |
#16 |
NICE! Love the sharks teeth! I had just measured my frame and concluded that it will have to be cut. I may brace it from the front with a cross brace or something to keep it rigid. I will have roughly 64-70mm of space vertically to fit a motor. So I will use that reference after I get the frame cut and mounted for a final estimate before I order whatever I find that fits. still looking to go 12S versus 10 just so I avoid yet another set of batteries that only work with one heli!
#17 |
Thanks,
The shark teeth really work good when I get out there!! I am setup for a 6S 5000 ma battery. Really works out. I have real time battery monitoring. I have so much electronics stuff around it. |
#18 |
And you have the metal side frames too? Any guess what your flight weight is? Maybe I could run a 6S setup and opt for longer flights with twi packs in parallel.... i just want it not to be too heavy and sluggish. You running the flex shaft or the belt? I just got the Hercules 14S BEC but it can run as low as 2S so I will opt to use a 2550 2S for the lights and Gatling gun and mechanics then dedicate the main lipo to the motor itself.
#19 |
Yes I am using metal frames.
Flight weight is Between 9 + 10 lbs. My servos run on 11.1 volts with a castle bec set for 6 volts. I have plenty of power when I fly. I run a dedicate lipo for the motor. I am using a belt. |
| Tags |
| cobra, hacker, scale fuselage |
