| Skookum Robotics Skookum Robotics SK-360 SK-540 & SK-720 Digital Flybar |
I'm running a trex 550 fbl & SK 720 on ver 3.02 usung a 600mx motor.
I have seen a couple of threads on the 600mx bearings failing. I check the vibration logs after every flying session and on 1-2 out of 4 flights I will get high spikes in the region of 15-20!! The heli seems to be flying fine and SL works, Im not noticing the red flashing led on landing? The odd thing is that I get one bad log then 2-4 good logs without altering anything. Suggestions would be appreciated. Was flying in 15mph winds last night and the heli is soooo stable, top job skookum! |
Please post a vibration log...ok check for the 20000 range.
Attached log files from the last four flights, self level worked fine on all four flights?
EDIT: My bad - didn't see it was vibe mode, not playback.
=] yes it's motor RPM's but not the motor itself, mainshaft shimmed correctly ie no play?
georgi UK |
#6 | |
The thing thats confusing me is that some of the logs have low vibe spikes but my flying has been the same for each flight? Thanks, Paul. |
#7 |
=] Paul hi, switch to playback logging and fly it like you do, lets see if we can map it to whatever input that raises the vibe, its quicker sometimes!
georgi UK |
#8 | |
Most of the time the vibes are really good, but I can see them rise to 7+ when I did a coupe of piro's when climbing out. I hope you can shed some light, or perhaps its nothing to worry about? Thanks Paul. |
#9 |
=] Paul hi, its mapping with tail inputs on either side, play in the linkages or extreme travels on the slider, or both perhaps??!
georgi UK |
#10 |
Thanks Georgi, I will check it out.
Did you use the dataviewer pro software to produce the graphs? Paul. |
#11 |
=] yes, the pro-viewer allows this kind of mapping, volts, RPMs, events, acceleration etc.
to go a little deeper into it here, (I have reviewed the vibe log files) the heli is flying really nicely, the tail is causing a vibe when its loaded, the motor can give a spike also in conjunction with the tail, so yes check right back to the maingear / tail drive which is where I was originally drawn to?
georgi UK |
