| 600 Class Electric Helicopters 600 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
I have a Trex 600EFL PRO (the latest version) and I want more power. The problem is that there is VERY little clearance between the stock 600MX motor and the pitch/aileron servos. What is the biggest, most powerful motor that I can put in this heli? Or is the 600MX about as big and powerful as I can stuff in there? Any suggestions are MUCH appreciated. Thank you.
Canomod Team Pilot | Goblin 700 GREEN | Goblin 700 YELLOW | Goblin 630 | Gaui X7 | Gaui X5 | Trex 700DFC | Trex 600DFC | Trex 250DFC | DJI FlameWheel F450 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Anyone? Beuller? Beuller?
KDE has a drop in replacement motor that's got a bit more power than stock. That would be your best bet. Not exactly sure of the model, but you can look it up here in search probably.
// T-Rex 600EFL Pro 3GX // T-Rex 450 Pro V2 3GX // T-Rex 250 Pro DFC 3GX // // Walkera V120D02-S (x2) // Walkera V120D02 // Walkera Genius CP (x3) // // EFlite Blade MCPX (x2) // EFlite Blade 120SR // E-Sky Belt CPX // // WK2801 // Spektrum DX4e // |
KDE
KDE 600XF-530
direct drop in and seems to be the motor of choice for the 600e pro EFL
Trex 600EFL Pro V2 V-Bar ds610 ds650 cc pro bec Scorpion 130a HV KDE 600XF-530 450pro 1860kv(6s) cc50 (4 DS215MG) 10t pinion, Tarot DFC, Ikon TBS Discovery (Quad), naza-gps, 900mhz fpv, gopro2, ET OSD pro, D/L UHF X-8 Wing , D/L UHF Full fpv package |
#6 |
Is it only a BIT more power? Or is it ALOT more power? If it's only a negligible amount of power increase, is it really worth it? What's your opinion?
#7 |
alot.
#8 |
A friend of mine recently stripped the mod 1 gears in his logo with one of the new HKIII motors from Scorpion. Those things have pretty big power.
Darren T-Rex 600 ESP V-Bar and RJX head, T-Rex 250 SE AR-7200BX, MCPx, and a Yardbird Heli To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#9 |
They have a very noticeable amount of power over stock. I can bog my stock motor down pretty low, but with the KDE motor (on a friends helicopter - all other electronics are the same, including batteries) it was much harder to bog. The climb rate was noticeably faster. Fight time seemed only a little less than stock, but we didn't time it, so I can't give you exact details.
#10 |
i ran a scorpion for a few flights recently and it got blistering hot. just hovering.
#11 |
Which Scorpion HKIII will fit in this? And I'm guessing I have to shim the pitch/aileron servos...so how would you go about doing that? With just washers?
#12 |
Anyone?
#13 |
The HKIII that many folks have popped in is the 4035 in the 500KV range for 12s. You have to shim the servos on their rear aft holes to increase their tilt in order to fully clear the scorpion motor can.
I will admit...the KDE motor being a direct fit I was a bit apprehensive that it wouldn't be much better than the stock align except build quality. Well....the heli went from really fast, to obnoxiously overpowered now. 2200rpm and 13.5 collective pitch and the thing is moving at 90+ in a matter of seconds. You're hard pressed at all to bog this thing provided you have decent packs. I'd say it's worth it with the scorp and KDE being about the same price.
Resident Mad Scientist E5-S KDE 600XF / 600N 55HZ 450 Pro V3 / Mod 130x / mCPX BL Mike D--AwesomeRC Hobbies |
#14 | |
