| Main Forum - Helicopter Talk R/C Helicopters and the people who fly them. VENDOR TOPICS DO NOT GO HERE. Full Scale Heli threads go in OT please |
#21 | |
I thought the poster meant some kind of phasing in the tail....and never heard of that. But main rotor phasing makes sense. Fun stuff.... Dan
Dan AMA# 987374 - T-rex (550DFC,550E, 500FB, 500FBL, 450-Sport, 450-Pro), Blade (400 Mcpx 120SR) - DX-7- And a ton of spare parts |
#22 |
going to say sounds like phasing
if you can hover inverted do a back flip to inverted note if the tail has moved then finish the back flip back to up right if the tail is back in line with you your issue is one of phasing
DX8 mSR, T-rex 500ESP 3G, Compass 6HV Savox servos Vbar 5.3Pro Rail Blades AMA#948801 |
#23 |
When I had this issue with my Trex 500, though not as dramatic as the OP, I ended up solving it by going FBL.
Rich Trex 500ESP FBL BeastX Synergy E5 VBar Synergy E7 VBar |
#24 | |
Dan
#25 |
I hear the term "collective management" all the time, does anyone have a clear definition for collective management?
Blade MCP X, Blade SR, Blade 450 3D Trex 450pro, Trex 500, Trex 600 Titan Raptor 50 |
#26 | |
It just means don't give hard stick inputs which can slow your headspeed or overwhelm the tail. Important on the Mcpx becasue of it's weak tail Dan
#27 |
Where does one go on HF to learn about phasing. Can someone maybe post a link to a thread that explains it well? Thanks guys.
Check out my Night Blades Blog here on HF |
#28 |
phasing is an issue with the how the swash is aligned to the rotor disk normally 90dec works fine but some helis the T-rex 500 is one of them need it more or less
ie more then 90 or less then 90 the easiest way to deal with it is covert to fbl or get head with adjustable phasing
#29 |
Ok thanks Elios, I think I get it. I will be using a 4 blade head with a FBL unit. I hear there are isssues with "phasing" with this. I will ask more about it in the scale forum when I'm ready for a flight test. Thanks again.
#30 |
4 blade head SHOULD be 90dec as well it only gets funny with 3 and 5 or more
see if your FBL has an option for adjusting the phasing of the head
#31 |
lol, yeah sorry, it was just that the advice turned into a phasing and control issue, when it should have been established if it was a gyro gain issue first.
Compass Atom 7HV, Scorp HK3 4035 hand wound by Mauro - 6x7x1.32 YY 430KV, CGY750 Beam E4, 6S, looking for a new FBL unit, BX is getting removed! Formerly owned - Blade mCP X V2 - Blade 400 FBL BeastX |
#32 |
the thing is both the T-rex 450 and 500 have know phasing issues
the 450 less so but the 500 has major ones only fixed by going fbl using a multi blade can also make any issues already there worse
