Go Back   HeliFreak > R/C Electronics Support > Scorpion ESC and Motor Support
Scorpion ESC and Motor Support Scorpion Power Systems ESC and Motor Factory Support Forum
Old 05-03-2012, 09:42 PM   #1
JTAnimal
Default HK4525-520LE shaft came loose
Hi, I had a crash on my Goblin and i have it back together now but i was doing some inspection and the motor shaft was loose. The klep ring was missing, not sure why. I loosened the set screws and pulled the shaft so i could get the pully off the end of the shaft but now i cant seem to get the shaft back in the motor all the way. i checked the shaft to see if its bent but it looks ok. it seems like i could get a new klep ring (the little washer was still on) and put it back together. any advice here?
JT
Trex 500, 550 & 600
Gob 700 & 700 KSE
JTAnimal is offline        Reply With Quote
Old 05-03-2012, 10:19 PM   #2
JTAnimal
Found the info i was looking for (video of how to change the shaft) but now i'm not sure if the motor is damaged, it may be. if the shaft came out without using a Arbor press is the can damaged. i pulled the motor out of the can and i can push the shaft into the can by hand. i'm feeling sick.
JT
Trex 500, 550 & 600
Gob 700 & 700 KSE
Old 05-04-2012, 12:28 AM   #3
Stolla
no problem as long as it doesn't move side to side, the grub screw will hold it
