Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600 PRO Class Electric Helicopters
600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 05-03-2012, 10:04 PM   #1
Commodore8888
Default Going Favorite Motor
So after popping the tail assembly off my Pro I was a bit miffed to find the 600MX was the culprit of putting a strong buzz through the airframe.
I noticed a little bit of drift today at 2150rpm on the beast so I went hunting. Tail is essentially vibeless with a belt and balanced blades (also checked by tail removal). Checked gear mesh and that was fine too (both main and auto).
Finally spooled up with just the motor and I found myself the owner of a very obnoxiously shaped women's toy.
Lockeroom hurr durr aside, what seems to be the going top motor on folks' list? I'm tempted to give other motors a shot as I've seen some pretty good stuff about other brands lately.
So far I've seen the 600MX with better bearings, the 700 size Scorp, the new KDE motors, and the Quantum stuff recently mentioned.
I'll probably rebuild the 600MX regardless. New bearings, balance the can, etc. It's put out decent power so far for it's size and having a good backup motor can't hurt.
Resident Mad Scientist
E5-S KDE 600XF / 600N 55HZ
450 Pro V3 / Mod 130x / mCPX BL
Mike D--AwesomeRC Hobbies
Commodore8888 is offline        Reply With Quote
Old 05-04-2012, 12:57 AM   #2
taoY
Depends on what caused the motor vibe. If the vibe wasn't there at the beginning, then probable cause is bad bearing(s). New set of bearings will fix it.
If the vibe is caused by out of balanced motor can, balancing the can will fix the issue. Provided if you know how to do it. I tried balancing the can my self but destroyed the motor completely.
If the vibe is caused by the off centered motor shaft (not insert into the can straight). Your best solution is a brand new motor.
I have KDE 600XF530 on my 550 12S for a couple months now and about 20 flights on my 600 Pro. A lot more powerful than 600MX. I am very happy about it and highly recommend it.
Good luck
Cheater
Cheater
taoY is online now        Reply With Quote
Old 05-05-2012, 12:33 AM   #3
Commodore8888
Balanced the can to check and it's still there to a degree. It looks like align drilled the can shaft hole askew so it wobbles with a straight shaft. One of the first motors that came with the kits.
The kde motor is the only one I know about that needs no shimming. This true for any others?
I'm really tempted for the scorp since I've had great luck before, but I'm not 100% about tilting the servos even more.
I'm pretty much against going align again when a scorp costs a few bucks more and is less likely to have a serious defect.
(especially irate since I have to find a motor with the fredericksburg fly in tomorrow)
Old 05-05-2012, 02:06 AM   #4
taoY
Yes, KDE motor is direct drop in replacement no shiming required.
Check this thread out.http://helifreak.com/showthread.php?t=385643
Only one motor with vibration reported so far and KDE took care of that immediately. KDE 600XF is much more powerful than 600MX. With 600MX, it felt soft under some maneuvers. With 600XF530, the power is there when I dig it. I have to admit my collective management is terrible. The extra power of KDE motor makes flying lot more fun for me.
Cheater
Old 05-05-2012, 02:53 AM   #5
smsodhi
I wanted toget the KDE motor recently as my 600MX also started to cause bad vibes, in the 1400's
What put me off was that I heard that it is hard on the batteries and you would need 65c ones, which I dont have so adding to the cost.
TRIABOLO P800 Kosmik HC3-SX 255/256
DIABOLO 4530 Kosmik HC3-SX 690/105 255/256
Futaba 12 FG
smsodhi is offline        Reply With Quote
Old 05-05-2012, 09:36 AM   #6
taoY
I may be responsible for this myth. You need a high C rating battery pack to get the full potential of the motor but it is not needed nor required. It is the same as car, to get more horse power the engine needs more fuel. The difference with electric motor is it can still sip the juice when it does not need that much. Also note the efficiency of KDE 600XF motor is higher than 90%.
I have Voltz 35C 3700mAh and Pulse 65C 3700mAh battery packs. After 5 minutes flight, the temperature of the Voltz packs are not higher than the Pulse 65C pack. None of my packs is puffed or shows any sign of damage.
The reason that I said KDE mortor is more demanding was because the voltage warning on my telemetry unit. It was set at 3.4v per cell - higher than what people normally set to. The alarm has never triggered after setting to 3.3v per cell.
Sorry if I cause the confusion. You will notice the difference when you put it on. I know i did. I can bog the 600MX easily with my routines but haven't managed to do so with KDE 600XF530.
Hope this helps
Cheater
Cheater
Old 05-05-2012, 11:39 AM   #7
smsodhi
Thanks Cheater
I went out and bought another 600MX
Never mind. Its a good motor for now, When it needs replacing I am sure that some thing else will be around, and by then I will need the power, thumbs willing.
Satnam
Futaba 12 FG
Old 05-05-2012, 12:40 PM   #8
Commodore8888
Guess I'll go for the KDE. The align has so for been impossible to balance with the buggered bell and the kde is only a little more than an hk3 scorp. The 600mx is a great motor when you get a good one from qc...but seems a good number of duds got through.
Still fuming. Going to end up missing the Spring Fling in fredericksburg over this turd >
Old 05-05-2012, 02:59 PM   #9
mhoebrec
You might want to read this : http://www.helifreak.com/showthread.php?t=410948
mhoebrec is offline        Reply With Quote
Old 05-05-2012, 06:13 PM   #10
NRPY
The two best replacement options are the KDE 600XF and the Scorpion HKIII 4035-560. The Scorpion will require excessive shimming of the front servos to get the can to clear, but it should work great. I have one in my 700, and it has loads of poop. I run the KDE motor in my 600 Pro because it is a drop in replacement. Very happy with it so far.
Regarding stock motor vibes, here is my contribution: http://www.helifreak.com/showthread.php?t=396289
NRPY is offline        Reply With Quote
Old 05-06-2012, 02:51 AM   #11
smsodhi
Just thought I report back about my new 600MX, flew it yesterday and bench tested it , very smooth so far. Very happy so far. Must be one of the lucky ones. Only thing that happened was that a brand new motor gearmount pinion bearing wore out in one flight. Must be a dud bearing ...I hope.
Futaba 12 FG
Old 05-06-2012, 02:09 PM   #12
Commodore8888
Lucky guy you are sodhi lol. The kde is in the mail. Hopefully I can wring it out at DCRC this weekend.
As for the 600mx, I was able to get the can balanced but the skew is bad enough the amount of balance weight needed is unacceptable. Usually align is semi decent about qc. Wonder what the heck they're doing to have so many turd motors get out. I'll be winding up the old 60mx with some better coil wire if I can find a properly drilled bell. It has good power and it's a bummer that it's too out of whack to balance the current can. Maybe shove into a laughably overpowered foamy.
