Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 05-03-2012, 10:22 PM   #1
whoanelly
Question question about conecting rod hitting
Hey guys , my engine(OShzr) keeps getting hot so i tore it down and i can see the connecting rod is hitting the bottom of the case ,not sure why but i can see its scratched up ..is something installed wrong cause ive taken all apart and cleaned to a tee thinking something might of been caught in there..
any help id appreciate..
700LE : 105HZR AR7200BX JR8917 Multi gov , JR9503
600ESP : 100AMP Castle. Scorpion Motor . AMA #962896
400 Blade : Scorpion 2221-6 ,Castle ICE 50 Sonix Head and t
Align 450 pro V2 3G MKS DS95 MSR , 2 x MCPX (brushless C05 & HP05), Blade 130X.
whoanelly is offline        Reply With Quote
Old 05-03-2012, 10:33 PM   #2
HiroboFreak
Most likely the rear bearing needs replacing.
T-rex 700n VBar 5.3 Pro | T-rex 700e V3 VBar 5.3 Pro
| JR DSX9 Limited
Team RCBits | Team Lynx
HiroboFreak is offline        Reply With Quote
Old 05-03-2012, 10:37 PM   #3
whoanelly
should i pull it out and check it out ? never pulled one out before ,ive got about 50 flights on the motor ,,just replaced piston ,sleeve and ring cause it got to hot..
Old 05-03-2012, 10:55 PM   #4
HiroboFreak
Definitely replace it, even more so because you have freshened up the rest of the engine.
Replace the front bearing while you're at it.
| JR DSX9 Limited
Old 05-03-2012, 11:05 PM   #5
whoanelly
ya i just pulled it out and it does feel a little notchy,, u can see it got real hot as well..
i sure appreciate the help..with that bearing messed up though would it cause the rod to hit bottom of case ?
ty
Old 05-03-2012, 11:06 PM   #6
HiroboFreak
Absolutely.
| JR DSX9 Limited
Old 05-04-2012, 12:06 AM   #7
whoanelly
Absolutely.
All ordered up ,,and thanks again for the help.
Old 05-04-2012, 10:10 AM   #8
ualdrivr
Replace the rear bearing once a year regardless and the front, maybe every other year as a precaution
At the precipice, we change!
Team GrandRC
ualdrivr is offline        Reply With Quote
Old 05-04-2012, 10:22 PM   #9
BlackWatch88
the back plate is what's holding the connecting rod and the crank sharft together, so its always scrached up
BlackWatch88 is online now        Reply With Quote
Old 05-04-2012, 10:52 PM   #10
HiroboFreak
He said "bottom of the case", not backplate.
| JR DSX9 Limited
Old 05-05-2012, 03:48 AM   #11
BlackWatch88
Not sure where is bottom of the case other than the back plate....
Old 05-05-2012, 05:12 AM   #12
HiroboFreak
The backplate attaches to the rear of the crankcase, the fan and clutch bolt to the crankshaft where it exits the front of the crankcase.
On the top of the crankcase you will find the cylinder head attached.
So the bottom of the case is.....
| JR DSX9 Limited
Old 05-05-2012, 09:44 PM   #13
BlackWatch88
RIght, but if you mount it in a heli the front become the top and the bottom would be..
still its werid if its hitting where you think its hitting...you need to have a realllly messed up crank sharft or rear bearing to acheive that. never saw it...
Old 05-05-2012, 11:04 PM   #14
HiroboFreak
Actually the front remains the front, it's just your perception that alters, hence the backplate is still the backplate, not the bottom plate.
The knocking noise you hear when the bearings are shagged is associated with the rod hitting the bottom of the case, as well as bearing rattle.
The engine also gets trickier to tune and can run hotter due to being under-compressed.
| JR DSX9 Limited
Old 05-05-2012, 11:25 PM   #15
Steve Graham
When I tore mine down to have the bearing replaced by Buzz Butlers Magnum Fuels bushing I also found evidence that the bottom of the rod had been making contact with the case in the fashion you describe. I think a loose bearing is the most likely culprit. BTW, I think this bushing idea has potential. He warrants them for the life of the engine.
Steve Graham
TREX 700N FBL...................GAUI X5 FBL...................TREX 450 PRO V2
Alees Rush 750 Still in the womb.
Steve Graham is offline        Reply With Quote
Old 05-07-2012, 11:38 AM   #16
whoanelly
i replaced both bearings this weekend and she purrs like a kitten now, I think when i smoked the piston that it damaged bearing as well but were all good now flew yesterday like brand new. Thanks again guys.
Old 05-07-2012, 04:13 PM   #17
HiroboFreak
Glad you got it sorted out.
| JR DSX9 Limited
