Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mSR
mSR Blade (eFlite) Micro SR Helicopters Information and Help
Old 05-03-2012, 11:21 PM   #1
deesman
Default landing skid upgrade
is there such a thing for the msr? i think ive bought about 100 of the things since i bought this heli 2 years ago
deesman is offline        Reply With Quote
Old 05-04-2012, 09:01 AM   #2
Kosem
Hi,
I for one am using the Xtreme skids for MCPx (Item Id: MCPX007) and I am very pleased with them.
I've tried the Microheli skids but they are pure joke, expensive and more fragile than the stock ones.
Kosem is offline        Reply With Quote
Old 05-04-2012, 06:42 PM   #3
digitalslacker
Yeah the micro heli ones aren't great. I went back to stock but those other ones look cool.
Sent from my Galaxy Nexus using Tapatalk 2
digitalslacker is offline        Reply With Quote
Old 05-04-2012, 07:07 PM   #4
deesman
those look nice, defiantly look like they will take a better beating . thank you
Old 05-05-2012, 04:04 AM   #5
Kosem
You are welcome ;-)
Because the MCPx batteries are wider than the MSR's, this is what I've done to guide and fit the lipos: 2 small carbon rods from an old training kit (instead of the screws holding the boom support) + a small piece of black velcro to stop the battery.
CG is perfect and the added weight is indeed insignificant.
Hope it helps!
Old 05-20-2012, 12:11 PM   #6
rjc57
Got a set on my msr, with a Mia S300 canopy. I like the canopy, but the TG landing skids from them was a joke. These are much better. I'm keeping the msr light, so I'm staying with the smaller lipos, had to mount a tray on the gear for these. Keeping it light so hopefully it will handle my 808 keychain cam, which is now on my 120sr. Had to build up the mounting pegs with CA, for a snug fit into the stock frame. All in all, was worth the trouble for a more scale looking S300. Thanks Rick
ID:	318095   Click image for larger version
ID:	318096   Click image for larger version
ID:	318097   Click image for larger version
Blade CX (retired)
120sr, trex 250 skids and boom supports, trimmed blades
mrsx, RKH aluminum grips and rotor head
mrs (used, from ebay), DXSi Spektrum radio
rjc57 is offline        Reply With Quote
Old 05-20-2012, 06:34 PM   #7
rjc57
And where did you get that light, Kosem?
Blade CX (retired)
Old 05-21-2012, 05:12 AM   #8
Kosem
It looks like there is no more blue light unfortunatly but few white leds here:
http://www.ebay.com/itm/E-Flite-Blad...-/290644664347
Old 05-24-2012, 12:18 PM   #9
Daryoon
Those extreme mCPX are so heavy compared to the stock. (I remember close to 3g) I hate giving up motor performance by adding more weight. The Heli loses it "pop" acceleration ability which one can feel.
Daryoon is online now        Reply With Quote
Old 05-24-2012, 03:41 PM   #10
rjc57
If I want to fly a heli, with "pop" acceleration, I fly my mrsx. The msr is a more relax
flyer, I use it to show off, hehe.
Blade CX (retired)
Old 05-25-2012, 05:01 PM   #11
rjc57
My search light installed. thanks for the info. Took out to my garage (with no windows), and just left one small light on and flew it. Twas a blast. Hopefully wind will calm down for evenings/night flight. I kept popping the throttle, and did some nice piros with the search light. Blinding, to say the least. Need to clean up the wires, hanging a bit, and looking into the 2012 tiny brite lights for it. Except for the canopy, and xtreme fly bar, and landing gear, the rest is stock. Did hit hard on the landing gear, held up with no problems. Good Luck Rick
ID:	319552   Click image for larger version
Blade CX (retired)
Old 06-04-2012, 02:58 PM   #12
schoep
I picked up a set of Xtreme skids for MCPx (Item Id: MCPX007) and find that they only fit 1/2 way into the frame when they make contact with the servos. Looking again at your pic. I now see that you don't have yours fully inserted. Whats your trick.
CX2,MSR,,R/C weapons pod, Camera pod, Scale Hughes 500 W/Blade 400 mech, HK450, HK500CMT
schoep is offline        Reply With Quote
Old 06-05-2012, 06:04 PM   #13
rjc57
I assume you're referring to Kosem's MSR. Looks like he has a MH aluminum frame upgrade, which has screws to hold the LG skids, and you can tighten them down not fully inserted into the main frame. I, however, just have the stock frame, and encountered the same problem of servo gears contacting the battery mount. I just took a Dremel and cleared away the battery tray, allowing the skids to fully inserts. Hope the photos helps. Thanks, Rick
Also, I used 120sr grommets body mount (o ring) , to hold the skids.
ID:	322251   Click image for larger version
Blade CX (retired)
