Old 05-04-2012, 12:16 PM   #1
rccopter
Default Question About Parts Tolerances (.03mm)
I am rebuilding my 450 after a crash The old flybar is 1.95mm in diameter and slides through the metal head fine. The new flybar is 1.98mm and it will NOT slide through - it's almost a perfect pressed fit. This VERY slight difference must be a manufacturing tolerance issue. I've tried polishing it with fine sandpaper and steel wool but can't reduce its diameter enough. I have a couple of new ones on order, hopefully they will be 1.95mm. Anyone experience these types of tolerance issues?
Thanks.
Rick
Gaui 550 w/ quark gyro, Spektrum dx6i radio, Trex 450, e-Flite Blade MSR, MCPX, 130X, e-sky Belt CP V2, Honey Bee V2
rccopter is offline        Reply With Quote
Old 05-04-2012, 12:29 PM   #2
markb
You could have ordered a Vbar. They always fit just right!
But seriously. No. When I used flybars, they always just slipped right in. Sure its the right one, and nothing in the head is buggered up?
Does one end of your old flybar slip right in - I mean, up until the bent part. I'm assuming its bent - hence the rebuild.
Mark
Logo 600se, Scorpion 5020-450, mini-V, Jive 80HV
Trex 600 ESP FBL, Scorpion 4025-740, cgy750, CC85HV
Trex 450 Vx FBL, Scorpion 2221-10, RJX head, mini-V, Ice 50
markb is offline        Reply With Quote
Old 05-04-2012, 12:52 PM   #3
rccopter
Yes, the old flybar slips all the way through fine (up to the bend). I'm saving my $ so I can convert my fleet to flybarless, but that won't be for a while.
Rick
Old 05-04-2012, 12:58 PM   #4
fastflyer20
You are experiencing the difference in .001" (.03mm), you go from a slip fit to a press fit. One of the reasons it is difficult to alway have press fits on bearings, etc. You would be better of enlarging the hole by .001" if you have the perfect size drill. It would still work fine with smaller FB rods.
fastflyer20 is online now        Reply With Quote
