Old 05-04-2012, 12:44 PM   #1
turko
Default blade 400 main gear
My hobby shop is out of blade 400 main gears.Will any other brand fit the Blade 400?, such as Esky or Align?
turko is offline        Reply With Quote
Old 05-04-2012, 05:16 PM   #2
wanderer56
Esky King 3 main gear should work. I've used a B400 main gear on the Esky K3 before. Don't see why it wouldn't work the other way around. But good luck finding Esky at a LHS.
Trex 500-3226-1600, 13T, Koby 90LV, HS-5245MG, DS520, AR7200BX, DFC
Trex 450 Sport-450M, 14T, RCE-BL35X, HS-5065MG, HSG-5084MG, AR7200BX, DFC
DX8
wanderer56 is offline        Reply With Quote
Old 05-04-2012, 05:44 PM   #3
SQRT(-2)
It does not look much like a Trex gear. I would just order one form Helidirect or the such. Throw in a few spare parts to make it worth shipping. You will have your new parts in a week. I like having some spare parts on hand anyway.
Gaui Hurricane 425 FBL with Robird G31 500 Class Rocks!
EFlight Blade 450 3D, Walkera Super CP
Walkera Devo 10 w/ Deviation
SQRT(-2) is offline        Reply With Quote
Old 05-04-2012, 05:53 PM   #4
Stormbringer
i beleive the blade 450 main gear fits but check out the blade 400 sub forum
http://www.helifreak.com/forumdisplay.php?f=98
MCX2 , MSR , MSRx , 120SR , MCPX v1 , MCPx v2 , Blade 400 3D , DX8
Stormbringer is offline        Reply With Quote
Old 05-05-2012, 03:39 PM   #5
Luvmyhelis
Yes, the B450 gear will fit, but you also need its new center hub to pull it off. You are stuck here as far as I know. Either pick up new B400 gears or upgrade to the microheli version. Which is superior in a half dozen different ways btw.
Luvmyhelis is offline        Reply With Quote
Old 05-05-2012, 03:47 PM   #6
jonbailie
I use a blade 400 main gear on my esky belt cpx. It has the same tooth count, and is a direct fit for the esky. Maybe it will work the other way around. Be aware though, the esky main gear is replaced by many for a reason: it strips very easily.
// T-Rex 600EFL Pro 3GX // T-Rex 450 Pro V2 3GX // T-Rex 250 Pro DFC 3GX //
// Walkera V120D02-S (x2) // Walkera V120D02 // Walkera Genius CP (x3) //
// EFlite Blade MCPX (x2) // EFlite Blade 120SR // E-Sky Belt CPX //
// WK2801 // Spektrum DX4e //
jonbailie is offline        Reply With Quote
Old 05-05-2012, 05:30 PM   #7
Luvmyhelis
Yeah, but has anyone ever seen a local HS that carries Esky parts? Not me.
Old 05-05-2012, 07:40 PM   #8
TowPilot
I'll send you a PM about B400 main gears I have, might help.
Mike
TowPilot is online now        Reply With Quote
Old 05-08-2012, 07:32 PM   #9
turko
Default one way installation
How does one go about installing the one way bearing into the main gear? Lub,heat, whats the trick?
Old 05-08-2012, 07:49 PM   #10
755 robert
What heli? On the trex 450s it is a press fit..A small vice works well..
700 class nitro,2X 600class electric,2X 450class,250 class,130 class,a few mcpx class(
).Dx-7.All helis fbl...If I had a dollar for every dollar I've spent on heli's ...I would break even.
.Who is John Galt?
755 robert is online now        Reply With Quote
Old 05-08-2012, 07:56 PM   #11
Kneedragger75
This tool, and a bench vice will remove,and install one way bearings. ,http://helidirect.com/align-one-way-...elis-p-408.hdx
So will the correct size sockets.
Raptor 50 OS50 Hyper, Futaba 520
Miniature Aircraft Furion 450, Spartan Quark
Futaba 9CHP
Kneedragger75 is offline        Reply With Quote
Old 05-08-2012, 08:04 PM   #12
Kneedragger75
A little hard to explain. Place the main gear in the bench vice. Use the appropriate
driver/socket to press the outer race of the bearing into a receiver socket/tool of slightly larger diameter.
This is the same procedure for most one way bearings.
Futaba 9CHP
Old 05-08-2012, 08:11 PM   #13
Kneedragger75
Installation is the same, except no drivers are needed. Simply press the OWB into the
gear until flush.
Futaba 9CHP
Old 05-08-2012, 08:52 PM   #14
pctomlin
Here is what I came up with to change out the OWB on my Outrage 550. When you learn to fly CP helis with a Belt CP you learn a couple of tricks. This will work for any heli, just need to size the pieces correctly. About 10 minutes in a home improvement store with the center hub and I was ready to go.
http://www.helifreak.com/showthread.php?t=334104
Paul
Outrage 550 - Castle 3434-1100, Ice 100, Bec Pro, 94758z, Total G w/JR 8900G
Outrage 550 - 4020-1390, Ice 100, Bec Pro, JR 8717s, Total G w/JR 8900G
Rave Ballistic FSO - HKIII 4035-560, Ice HV160, Bec Pro, JR 8717s, Total G w/BL-9188
pctomlin is offline        Reply With Quote
Old 05-08-2012, 09:17 PM   #15
Slyster
put your heli(s) in your signature. It just makes life easier for everyone
It's not just a hobby... it's a lifestyle!
Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo
Pete Team Outrage.
Slyster is online now        Reply With Quote
Old 05-09-2012, 12:07 PM   #16
turko
Default one way
Thanks everyone.
Blade 450 heli,Mks 92'scyclic, Eflite g210 gyro,ds76t, Dx6i
Old 05-18-2012, 01:58 PM   #17
turko
Default gear problem
I installed a new main gear on my blade 400.All was well, gear mesh was perfect, so I took her out and within 1 min. I noticed heli was acting funny.It was like the main gear and tail gear fused together.I cuold not manually spin main or tail gear and after a few minutes of trying they let go and spun normally.So I put motor back on and went to fly again and same thing happened.Any ideas? I have rebuilt heli quite a few times and gear is not upside down or anything else like that.Maybe a bad one way bearing?I'm stumped.
Old 05-18-2012, 04:57 PM   #18
SQRT(-2)
Sounds like a one way bearing to me.
Old 05-21-2012, 02:05 PM   #19
turko
Default main gear woes
I bought a new main gear with one way bearing for my blade 400.I could tell something wasn't right and it appears the oneway bearing isn't seated properly and therefore it is not spinning true.Is it possible to fix this or should I return it to place of purchase?
Old 05-21-2012, 04:13 PM   #20
ahahn
I'd say return it.
I am not familiar with that maingear setup, but the one-way bearing is pretty sensitive to how it is mounted in the hub. In other words, you can damage the one-way if you over compress it in getting it into the hub.
At least I was able to damage mine when I tried to get a new one into an Align 250 SE hub. I just buy the entire setup now!
ahahn is offline        Reply With Quote
