Old 05-04-2012, 08:13 PM   #1
celm
Default 3300 MAH lipos,is that enought?
i have plenty of 6s 3300mah 30C lipos,are these lipos to small for the 700?
Trex 250 SE FBL SK720,CX450 Black Angel Airwolf FBL 3G, Trex 700E FBL V-Bar ,Logo 600 SE FBL V-bar, Logo 600/550 FBL V-bar,Logo 400 FBL V-Bar ,Goblin 500 V-Bar, Blade 130X , Blade MCPx
celm is offline        Reply With Quote
Old 05-04-2012, 08:27 PM   #2
Blink 182
Too small, those are more suited for a 600 size with 12s. But it will work, just dont expect good flight time.
(´・ω・`) ギルティクラウン
(´・ω・`)
(´・ω・`)
(´・ω・`)
Blink 182 is offline        Reply With Quote
Old 05-04-2012, 08:39 PM   #3
justindewoody
You will get about 3 mins of flight time with those. You need 5000 mAh batteries. I use Turnigy Nano-Tech 45C 5000 mAh batteries (2 of them in series of course) and I get about 6 mins of flight time.
Canomod Team Pilot | Goblin 700 GREEN | Goblin 700 YELLOW | Goblin 630 | Gaui X7 | Gaui X5 | Trex 700DFC | Trex 600DFC | Trex 250DFC | DJI FlameWheel F450
justindewoody is offline        Reply With Quote
Old 05-05-2012, 12:52 AM   #4
cd5
i get 4mins out of 4000mah. dont forget c rating is also related to capacity. i wouldnt go smaller than 4000mah or your going to kill those packs fairly quickly/
trex 450 pro
MA furion6
Synergy N5
cd5 is offline        Reply With Quote
Old 05-05-2012, 01:10 AM   #5
Blink 182
C rating is not related to capacity, it only determines how many amps can be delivered by the pack.
(´・ω・`) ギルティクラウン
(´・ω・`)
(´・ω・`)
(´・ω・`)
Old 05-05-2012, 01:12 PM   #6
weedwacker
I ran 3300s last fall. Flys uber light loved it. I have no 3300s left for this year
7HV | sz 4926 | Hyperion Phase sensor | Helijive 120 | VBar Fullsize Blue | Torq HV's
Trex 700e 3G | 700MX | Ice 120 HV | WR Hercules | I2 Tri-Blade Tail| RotorTech 105's | Voltz 3300 6s x2 | Lynx Spindle Bolts
weedwacker is online now        Reply With Quote
Old 05-05-2012, 01:31 PM   #7
celm
So pretty much u killed them?
Old 05-05-2012, 05:39 PM   #8
cd5
c rating is related to capacity.
1c equals 1x capacity .
So if you charge a 5000mah pack at 1c, you charge it at 5 amps. To charge a 4000mah pack at 1 c you are charging at 4 amps.
The same goes for discharge. A 10c 1000mah will supply half the amps 0f a 10c 2000mah pack.
So that is why a larger capacity pack will supply more amps than a smaller capacity pack of the same c rating.
Of course this is comparing to different capacity packs of the same c rating an chemistry construction etc.
Back when lipos first came out, some of the cheaper brands would claim that they had a newer higher c rating pack. The pack was physically larger than the same capacity pack of the lower c rating. And you would recharge them and put 5000mah back into a 4000mah pack. They hadnt increased the c rating just the capacity and still labelled them as lower capacity.
Nowdays people are more factual in the labelling and you can have an increase in c rating without altering the capacity and size of the pack . But a 65c 40000mah 12s pack of brand A is not going to supply less amps than a 65c 5000mah pack of the same brand A.
trex 450 pro
MA furion6
Synergy N5
Old 05-05-2012, 09:11 PM   #9
justindewoody
+1
Old 05-05-2012, 09:18 PM   #10
stockman
Excellent post.
Trex 700e V2. All stock except for V2 tail upgrade and BeastX FBL. 2x Zippy 5000mah. Hitec Aurora 9 TX, Optima 7 RX.
stockman is offline        Reply With Quote
Old 05-05-2012, 10:14 PM   #11
weedwacker
I cant say for sure if thats why but yes, 4 sets are dead. The larger ones are still fine. One i did undervolt, not a lot of room for error if you dont reset the timer.
