| JR and Spektrum Radios and Electronics JR and Spektrum Radios, Gyros, Servos, Etc. |
I've had this radio, which I purchased new, for 11 months now and everything has been fine, but I had only 2 models on it, and both were helis. In the last 2 months I have expanded my fleet to include 2 MCPx's, a UMx GeeBee, a Twisted Hobbies EPP foamie, and a Miss Hyperion hydrofoam. All of the model selections and all of the control functions work fine on the various models, but the timer keeps randomly resetting. I have all of my models set to count down, and use the timer switch to activate. Now I notice my timer is counting up instead of down, and it switches randomly from one model to the next, so that I have to check it every time I fly a particular model.
I have tried setting all of the switch's to "0" before I turn it off, I've tried not turning it off before flying a model I switch to, and every other senario you can think of. Nothing seems to help or make a difference. As I said, it is quite random. It wouldnt even really be a problem, but it always resets to 6 min., and not everything I have flies for 6 min. Just curious if anyone else has had or knows of this issue, or am I just the "lucky one"?
My Dawgz Got Madd Skillzz! Heli #1:Gaui 200V?/FBL/BeastX V2.05/Gaui 5600/CC25/5065 MG's/DS09 GMD/Spektrum Sat. Heli #2:Gaui 200V?/FBL/Gaui 5600/CC 25 ESC/65 MG's/BeastX V3.08/DS09 GMD/Spektrum Sat. |
Sounds like you might be one of the "Lucky ones" . I think there is a service bulletin out on the issue. It has come up before. You might check Spektrum's website.
http://helifreak.com/search.php?searchid=9254944
Trex 500-3226-1600, 13T, Koby 90LV, HS-5245MG, DS520, AR7200BX, DFC Trex 450 Sport-450M, 13T, RCE-BL35X, HS-5065MG, HSG-5084MG, DS760 DX8 |
Yep, you're right. I did a search and found this is a well known problem. Seems to be some type of firmware issue. What is odd is I have seen alot of discussion on the problem, but not a fix. Seems you have to send TX and no one does. Might give Horizon or Spektrum a call and see what they have to say about it.Thanks for the heads up.
That's ashame. The DX6i was such a trouble free tx. It seems like a lot of these started with the DSMX release.
intermittant-not all the time.
Unfortunaley I modded my Tx (backlight) and now I can't send it back? Tedolph |
#6 |
I have the same issue with mine, in addition to two other issues.
About 5 months back I was at an indoor fly-in event and my Blade 450 3D was tipping on spool up. Since I had the RTF version I just copied and preset over to "fix the issue and go fly." Fast forward to a couple weeks ago with the T -Rex. It tipped after a full idle up spool and shredded the blades when I went to lift off. After the walk of shame and mandatory cool off period I looked at the T-Rex model settings and discovered my BL MCPX settings were copied to the Trex model memory, 1 swash servo, extremely high servo travel range on rudder, expo, etc! ![]() I haven't yet called Horizon. Just got a 9503 in the mail to replace the 6i.
x5 / align 450 pro v2 / 130x / mcpx / 9503 / pl8 |
#7 |
I had this happen on my mCPX profile; it seemed to (mostly) occur when I switched the TX off without resetting the timer manually after having stopped it. Can't remember if it was over-time or had been stopped under when it happened most often, but the next time I powered the TX on (and until I fixed it) it'd be set to UP mode with some time on the clock (either 4:30 or 6:00) and reset to 0:00 when started and count up.
Remembering to reset the timer before shutting the TX off has become a habit though, and it hasn't happened again in about 5 months since I'd started doing that.
Blade: mCX2, mSR, mSRX, Nano-CPX, 2x mCPX (v1), mCPX-BL, 120SR, 450 X Spektrum DX8, DX6i |
