Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450
Blade 450 Blade 450 Helicopters Information and Help
Old 05-05-2012, 04:34 AM   #1
Mikey2
Default Ideal gyro and tail servo for 450 3D
If I were gonna upgrade these two components to perform better and more "locked in" than the stock gyro and tail servo on a 450 3D, what would you recommend? Despite trying various setup combinations and headspeed / pitch / gyro variations, the tail control on this unit is "quirky" and sorta twitchy. More headspeed seems to improve tail control and authority but still get some "hunting" as if the gyro just can't quite figure out what it wants t' do.......................or the tail servo reads those inputs just fine and then sorta scrambles the message. This doesn't make the heli unflyable........................just sloppy looking and twitchy in hover especially. It'll sit there hovering and then just "twitch" where the tail will just quickly kick out. Reducing / increasing gyro sensitivity serves merely to increase / decrease the frequency of those twitches. It's a little smoother at lower sensitivity settings but then it sorta wallows around down that far as well (60's or lower). This has been going on for nearly a year, the heli has never been pranged (not even a minor blade strike) and all other components work smoothly and reliably..................even the stock motor hasn't yet come apart.
Mikey2 is offline        Reply With Quote
Old 05-05-2012, 05:43 AM   #2
gixster
I used the Spartan Quark Gyro, with the Hitec HSG-5084MG. Very easy to set up and rock solid.
If that ends up being something you may be interested in,I have the Gold aluminum Quark With the datapod, both like new, never crashed.
Iam in maple grove, MN. If wanted to i could let you try the gyro on your heli.
if you like it, sure we could work out a deal on them if wanted. I recently converted to FBL so really don't need anymore.
Synergy E7SE / Synergy E5s / Blade 180 CFX
Futaba 14SG, DX9, Real flight 7.5, ACCURC
gixster is offline        Reply With Quote
Old 05-05-2012, 07:33 AM   #3
buddha2490
if you like it sure we could work out a deal on them if wanted. I recently converted to FBL so really don't need anymore.
Take him up on that. Quark + a decent servo is perfect. I also have that servo and a quark, but I imagine any good servo would be fine. It is the gyro that makes the most difference and the quark is sweet.
Blade 450, Scorpion 2213-14 motor, Quark Gyro - cheapo blades
Blade MCPx V2 - Now Brushless!
buddha2490 is offline        Reply With Quote
Old 05-05-2012, 03:08 PM   #4
Relisys190
Spartan Quark=the best available.
*LINKS*
* G660c IKON * T-rex 500 *308DUO *450x #429
Relisys190 is online now        Reply With Quote
Old 05-06-2012, 05:48 PM   #5
Heli.Maniac
+1 plus you can find some very good deals on the net now that FBL is so popular. I even saw 50% off at Fast-Lad, not sure though.
Andreas (formerly known as anmatheextreme)
Compass 7HVU
Logo 600SX CF
Blade 450X
Heli.Maniac is offline        Reply With Quote
Old 05-06-2012, 08:27 PM   #6
Chris Gardill
Just put a Quark Gyro and a Futaba S9257 tail servo on mine this weekend. Pretty easy setup thanks primarily to Finless's setup videos. Took two flights to get gyro gain where I wanted it. Amazing difference even though I'm still experimenting with gain. Much more locked in and no wandering that I used to experience with the stock setup.
Synergy E7SE (KDE 700XF-495) (under const.); Synergy E5 (KDE 600XF-530); Goblin 500 (XNova 4020-1200); Gaui X3; MSH Protos; Blade 350QX; Blade 200QX.
Chris Gardill is offline        Reply With Quote
