Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis
Thunder Tiger Electric Helis Mini Titan E325, Raptor E550 and E620 SE Helicopters
Old 05-05-2012, 04:37 PM   #1
chris4214
Default MT V2 can not pit other brand motor?
Hi, I'm building a MT v2 FL..
I just bot a kit and building with my own electronics..actually the kit has few problem..so spent a lot of time for fixed it.
but now I installing my electonics..and got some problem..
I tried to pit kds 3500kv motor..but can't becoz the motor mount size is different.
I checked distance between screw hole to hole on motor. it's 16mm, just same as align 450 motor.
Also checked distance between screw hole to hole on motor mount. it's 20mm..
is tt motor dimension different ??
as I know mt se can install align motor..and also can install TT OBL 29/37..the OBL 29/37 is also stock motor of mt v2 but v2 can't install align motor.
v2 only can install TT motor? or they sell another size mount for v2?
chris4214 is offline        Reply With Quote
Old 05-06-2012, 08:33 AM   #2
Procfrk
Post a picture of your mount. If it's like the mount on the other TT kits; there's a couple different mount hole orientations you can use. IE move the motor clockwise on the mount and see if the holes line up in another spot.
Trex 500 FBL w/iKon, Mini titan FBL w/beastx, Trex 250 FBL w/beastx, nCPx -> dx8
Procfrk is offline        Reply With Quote
