Go Back   HeliFreak > Multi Rotor Support > Blade Multirotor Support > mQX
mQX Blade mQX Quad Helicopters Information and Help
Old 05-06-2012, 12:30 AM   #1
BigRHS
Default Got my MQX tonight
Hey guys,
I got a new toy tonight and i hoping all you experts can give me all the info i need to get started.
I am new to quads and to be honest, I wasn't even planning on getting one right now. i actually went to my LHS to get a new MCPX. One of the techs was playing around with one inside and it looked like he was having a ball !
There were a couple of other customers there that own one and they were all saying how much fun it was and that I should try one of those.........so, instead of a MCPX I came home with a MQX .
Now i just need to read the manual and a setup thread on here to learn the best setup for it and my DX6i.
Guys, please feel free to part any knowledge on me you feel could help me as a total noob to muti-rotor.
Right now I am flying the MSRX and I'm on that forum a lot and also I fly..........well, fly may be the wrong word for what i do with an SR............here, this describes it very well
Anyway, thanks guys and i'll be on here a lot from now on it looks like !
Any and all help and info will be greatly appreciated !
DX8, 1 Brushless MSRX, 1-130X, Venom TX case
BigRHS is offline        Reply With Quote
Old 05-07-2012, 07:54 PM   #2
basmo
First, I'm no Expert by any means...
Welcome BigRHS, I've been mainly in the Blade 450 forums, but since I bought the MQX, find it interesting reading all the information so far in this forum! I'll have to say, this is one product that Horizon / Blade under-advertised and over-delivered in my mind. Very fun flyer.
Just a couple ideas (probably already listed somewhere in this forum), you can program the DX6i for either the airplane or heli mode for the MQX. The heli mode will allow you to utilize the 'throttle hold switch' for safety, plus input a throttle curve. I bring this up now, because when you are ready to do flips and rolls (yes, it will do them), I find you need a little throttle on to keep stable (while in the inverted portion); but, not too much to where you push towards the ground! You can also just lower the throttle stick a little (slightly lower than mid-stick) while inverted, but for those that stick bang...
For dual rates, I have mine set at 60% for low rates; 100% for high. For outside flying, better to use the high rates in my opinion. Good luck, have fun!
Blade 700X; Trex 700e dfc, ar7200bx, cc120hv
JR Vibe 50 Nitros
TT Raptor V2 (50 Nitro) w/MD-500 Body
Blade 180CFX
basmo is offline        Reply With Quote
Old 05-08-2012, 10:56 AM   #3
BigRHS
Thanks so much for the reply, I was beginning to think I had a plague or something.....LOL ! A lot of views but no reply's.
I have to say that this thing has been a blast so far.
I did set it up in heli mode and I have mine set at 75% with 20 expo for inside and of course everything set for 100% for outside.
I did have some issues with orientation and I thought those days were over, but this thing looks so different in the air i found that I was having a little trouble when I got it a little high or farther away from me.
I added some red shrink wrap to the 2 front spars and painted the tips of the white blades red on the top and bottom and that really helped.
I also took some advice from some guys on another forum ( RV groups ) that told me to make a homemade canopy so i don't break the OEM learning to fly the Q since the OEM is so fragile.
I started to make it out of a bottle bottom, but I looked over at my wife and she was eating some peaches out of one of those single serve plastic cups and that gave me the idea of what to use. it works great and is tough and lite.
here's a pic of it.
Thanks !
Old 05-08-2012, 11:11 AM   #4
ErikIL77
I used a two tone scheme when I painted mine so I can top from bottom as well. The top of my "cup" canopy is red to match the rotor tips and the botton is blue. I used a mini tuperware thingy with a lid that helps to keep it in place. I had issues with the orientation when I was doing my figure 8s from the side instead of around me and this helped a lot.
The frame is very durable compared to an MCPX. what would snap a tail boom will maybe bend a blade on the MQX. The blades are cheap so its not bad to have a few of each type. Note that you have CW and CCW.
Engine failure seems to be the biggest complaint. I recommend keeping one of each type on hand just in case. I had to replace one of my CW motors after about 20 flights. I run mine in + mode and there was a noticable lag on banking right.
ErikIL77 is offline        Reply With Quote
Old 05-08-2012, 11:57 AM   #5
BigRHS
Thanks man,
Is there an advantage to running the + mode or is it just a matter of preference for the pilot ?
I have been thinking about painting the inside of my fruit cup canopy, but I don't know how well it will handle paint and I figure it will just add weight.
I want to get a better canopy once i get better at flying it.
Do you do flips with yours, and if so, what is the procedure to do one ?
I have seen video's of guys doing it, but not one on how to do it.
ps: what are the decals for that came with the Q. Are they just to put wherever you want them or is there a certain place they go. i can't seem to find anything about them in the manual.
Old 05-08-2012, 12:38 PM   #6
basmo
Just a few steps I found works for the flips (either forward or back):
- Get enough height, it will drop a few feet
- Give full back (or front) elevator
- When it is inverted (or right before), lower the throttle to approx. mid stick or slightly below
- Keep full elevator
- As it comes around back to upright, relax elevator and quickly add throttle to hovering position.
- They get a little better each time; you can 'smooth' them out
JR Vibe 50 Nitros
Blade 180CFX
Old 05-08-2012, 12:57 PM   #7
ErikIL77
Originally Posted by BigRHS View Post
Thanks man,
+ or X seems a matter of preference. I tried both and prefer + for flying around and X for attempting stunts.
So far for my flips and rolls I have found not doing them from a stand still is easier for me. I will get my MQX traveling up before I attempt a manuver, with the first few times setting up for something like a stall turn for extra advantage. I jack my travels to max (%125 on a DX6i) and set negative expo for faster response on the stick movement. The first few times ended with me pancaking the thing to the ground so height is your friend. Cut the throttle as others have mentioned once you get inverted.
Old 05-08-2012, 03:56 PM   #8
BigRHS
Now all I need is some calm days so I can get it outside and give it a try ! Can't wait to try some flips and stuff, i just can't get over how much fun I have had flying this thing. I guess it's just the fact that it's close to flying a " regular " helicopter but different and stable enough to be fun !
Old 05-08-2012, 04:30 PM   #9
ErikIL77
It is fun flying it against light winds, just be careful once you get above the tree line.
Old 05-08-2012, 11:31 PM   #10
BigRHS
It's been raining here the last couple of days, but as soon as I get the weather I'm heading outside with it and see what I can do !
Old 05-08-2012, 11:33 PM   #11
GSPI
Go with lower expo settings and fly it indoors too for practice! I've flown it around an office area without too much issue. Then I have the higher rates for the quick responses needed outside! This is a lot of fun!
OXY Heli and Lynx Heli Innovations Team Pilot
SilentDRC.net -The Order of Brushless Witnesses
GSPI is offline        Reply With Quote
Old 05-08-2012, 11:54 PM   #12
BigRHS
Oh, i have been flying it inside ! i have flown everyday since I got it and have had a blast ! I have almost forgot about my MSRX and SR over the last couple of days, but some of that is simply because it's " the new thing on the block right now ".
I have my rates set at 75% with 20% expo for inside and have everything set for 100% for when i go outside.
