Go Back   HeliFreak > R/C Helicopter Support > Turbine Helicopters
Turbine Helicopters Turbine R/C Helicopters
Old 05-06-2012, 07:05 PM   #1
aviatorflyer
Default Kero start Wren 44 won't start
On initial spool up it ignites for a few seconds, then smokes & never spools up puddles of fuel in exhaust.Checked the valves, pump , glow plug with the computer.If I prime the start w/computer it runs a little longer.Removed the main fuel line from the filter before the engine & ran pump . Should there be a lot of pressure there or just a trickle? Could the glow plug be weak?
aviatorflyer is offline        Reply With Quote
Old 05-07-2012, 03:30 AM   #2
Vortexx
I have heard of a few guys having issues with the burner element gumming up restricting the kero flow in the burner.
You can test it by removing it, connecting the pipe with a locknut where it screws into the combustion chamber, connect the cables and test the burner outside the combustion chamber. Be Warned.....It will throw a flame so be sure to place it somewhere it won't burn your house down before you try it.
If it doesn't throw a good flame then you will need to carefully disassemble the burner and clean the gum and deposits from inside it and you should be good to go. They have very fine clearances which can clog up and stop the kero flowing.
Easier still if you have a spare burner handy try that first.
Regards,
Lance
Old School Heli Pilot and MAAA Heli Instructor
MA Spectra T Wren44 | MA Spectra G Toxic 231 | MA Stratus YS91SR | MA ProII YS91FS |
MA ProII YS61STII |
Kasama Srimok N90 YS91SR | Ergo 3D OS46FX | Ergo30 OS30SX | HK600e | HK500e |
Vortexx is offline        Reply With Quote
Old 05-10-2012, 10:15 AM   #3
aviatorflyer
New fuel pump solved the problem.
