| 550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
#21 |
#22 |
In the manual it states that the head speed should be between 2600 and 2700 rpms, which is way higher than the CC ESC allows. Is that just a typo in the manual?
"There's nothing wrong with fast. You can always throttle back" -Flying field buddy |
#23 |
Actually, the manual says to run it at 100% throttle (slant gear V2) up to a smoking 2800 RPM!
How do you do this with the CC? Throw in 7S to trick the calculator, or just run fixed endpoints and use fixed 90% and 100% throttle curves? Is the governor mode really better than just running 100%? It seems that people are surviving at governed 2200 headspeeds, but that just sounds really slow compared to the chart in the 550 manual. It even sounds like the numbers in the 550 manual could be wrong, as suggested above.
Too many helis, too little time. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Spektrum DX8 |
#24 |
Fixed endpoints in my stock FB 550. With 550mm Rotortech (heavy) blades I get 7mins of flight at a tached headspeed of 2350. 90-80-90 that's my idle1. Idle2 is 100-90-100 and that tachs at 2550 With 5mins of flight time doing the same manouvers.
Robert "Full" Montee Whiplash | T-Rex 600N Awesome RC Hobbies |
#25 |
Anyone else?
#26 |
Stock setup running at 100% flat curve on ESC will yield 2550-2600rpm.
If you factor in the head room needed for the Castle governor to work correctly then this is why you are limited to 2250-2300rpm in the software. If you want more head speed then you are going to need to change the gearing from 11T pinion to a 12T one and this will let you bump up the headspeed in the Castle software. Hope this helps.... |
#27 |
I just got mine from someone and it is running a 16t pinion, which I note is the stock pinion. Why would one gear down to an 11? Looks like the manual is close to correct on head speeds.
#28 |
11t or 12t is for the slanted gear.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. SAB Goblin 700 - CCHV120 - BEC Pro - AR7200BX - TM1000 / T-Rex 450 Sport - 3GX - Tarot head / 450 Pro - GT5 - Tarot head / T-Rex 550 V2.1 - CC100 - BEC Pro - AR7200BX - TM1000 / |
#29 | |
Hope this helps... |
#30 |
No problem. Thought I was loosing my mind or I was going to have the only 550 turning 3000 rpm!
#31 |
#32 |
would having a gov gain to low give it the feel of low headspeed?
Trex 250 SE FBL SK720,CX450 Black Angel Airwolf FBL 3G, Trex 700E FBL V-Bar ,Logo 600 SE FBL V-bar, Logo 600/550 FBL V-bar,Logo 400 FBL V-Bar ,Goblin 500 V-Bar, Blade 130X , Blade MCPx |
#33 |
So what is the correct head speed? Is the manual incorrect?
#34 |
OK, so those of you that have tried BOTH governor and fixed endpoints. Whats the actual flying experience with one way vs. the other?. Most people are using between 2250 and 2300 HS for governed and 2500-2600 fixed end points. Thats a pretty vast difference. Whats the real world difference between flying with a faster HS in fixed or a governed lower HS? Besides better governed runtime : ) Is the higher HS better for tail gyro and FBL systems?
#35 |
Having a gain too low you will hear the helicopter struggling to find the head speed you desire. It will sound like its cutting in and out. It will not necessarily sound like too low of head speed. Too low of head speed is exactly that, too low of head speed.
Synergy E7 Trex 700E DFC Goblin 500 Blade 130X Hold My beer and watch this ;-) |
#36 |
The manual is correct!! The helicopter was designed to be ran on an Align ESC which most people realized wasn't that great. When you run the align esc you run non governed, which makes your head speed with the gearing and 100% 2600 rpm. That's how it was designed to run. When you start switching to the Castle you want to run the heli in governor mode which a lot of people like because it will give you the same amount of power at the beginning of the flight as at the end. Only problem is is that the Castle doesn't give you room for that high of a governed head speed and no one is changing their gearing. So many people have switched their esc and have been running a governed 2300 with Castle that it has become the norm. It is not normal, that is extremely low head speed. You have to change your gearing. Then you can run what the manual has called for and also governed and you have the best of both worlds. I run a governed 2600 HS with a 115/14t set up. Hope this clears up the confusion.
#37 | |
#38 |
i had to go back to straight throttle curve about a month ago to chase a problem and even running 90-100 flat curve and the higher hs that came from it the heli lost a lot of pop on hard punch outs, for me it bogged much more than when on 2200-2300 governed hs. could be the predictive nature of the vbar gov that gives the extra punch even with the lower hs and i got a bit more flight time on the governed mode. after running both i would def prefer to not run flat curves again.
Trex 450pro FBL Mini V Bar, YGE 60, scorpion 2221-8 Trex 550V2 FBL V Bar, YGE 100, kde 600xf-1100 mCPx 2 Trex 700e dfc hv V Bar silver line, CC Ice2 120hv |
#39 | |
#40 | |
Thanks again! Sent from my iPad using Tapatalk
