| Atom 7HV Compass Atom 7HV Model Helicopter Discussion |
#21 |
I wasn't able to make 17.5mm work with my 8900G and Vbar. I am at 14.5mm on the tail. It works well enough. No wags.
= R To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. b43 = Team Compass Support |
#22 |
Last friday I replaced all kind of parts like main shaft complete rotor head. autorotation hub and the problem still remains. I almost completly rebuild the heli and the problem doesn't go away. I hope there will be a remedy soon.
#23 |
Hey Emile,
Witnessed two other issues like yours after our long session on Friday... Please pull the tail hub apart again, and put one end of the Hub spindle in a drill ans see if it wiggles (I know it's new). If it does get yourself a straight one. Grt,Eric
One day I got stung, and now I love rotor sounds...Team RIGIDHELI.COM T-Rex 700N Pro, Compass 7HV ult., MSH PRÔTOS |
#24 |
I know you said the links are sized properly but you might want to double check. I had issues with mine and after re sizing them and replacing them (sized them too much), I still couldn't ever get them right. Ended up switching to some out rage balls and it worked like a charm.
Team Synergy VP Racing Fuels Team Scorpion |
#25 |
And maybe also the bearing blocks:
http://helifreak.com/showpost.php?p=3959574&postcount=4 I remember your main shaft did go in or out pretty difficult too.
#26 |
To add to EricW's reply, a few have recently discovered the trick to fixing bearing block misalignment is to separately square up the upper frame portion with is detached or loose from the lower portion.
http://www.helifreak.com/showpost.ph...0&postcount=22
#27 |
Thank you for all tips guys. I was a little bit busy this week with work. So I will take some time this weekend to test all your suggestions. I will also try another tail probarly if it doesn't work
#28 |
Let us know how it goes...
#29 |
Yesterday I solved the problem. So thanks to all you guys which helped me solve the problem. I replaced the tail which included.
- tail hub - tail bearings - tail grips It's weird because I replaced it all. But the only thing that counts that I am happy again |
#30 |
I heard it from Rogier allready ( we all got frustrated a bit with it...., unbelievable
Great it's solved!!, rip some sky with it now
#31 |
It turns out that my tail wag was caused by the governor of HW 120HV ESC. I disabled it and tail wag is now gone. I know Hobbywing is currently looking ways to improve governor function, hope that helps. Otherwise I have look other alternatives (other ESC or FBL box with gov function) because I really enjoy flying with governor.
Warp 360 - Brain | 7HV - Brain |
