Go Back   HeliFreak > R/C Electronics Support > Scorpion ESC and Motor Support
Scorpion ESC and Motor Support Scorpion Power Systems ESC and Motor Factory Support Forum
Old 05-08-2012, 12:33 PM   #1
ilkeresmer
Exclamation Please Help!!! Scorpion 130A 50V AR7200BX!!!
Hello to all,
in my goblin when i bind the batteries my esc makes a sound like di da di da di da , i m using hercules bec at my system with ar7200bx , and i bought some cables for rudder and esc to make it longer.... please look at the video and help !!!
The problem is, when i plug the batteries , my ar7200 doesnt see the esc's signal. Sometimes it works after 20 seconds sometimes it's not working. When i played with the Ar7200's throttle channel upside down with the esc's cable that pluged, it takes the signal. I am sending you some videos about the problem. please help me!!! I bind another receiver , it is also spekturum AR7000 , ESC works perfect on it!!!
ilkeresmer is offline        Reply With Quote
Old 05-08-2012, 12:48 PM   #2
ilkeresmer
i tried it with a normal receiver and it works normal, (with AR7000), but with the Ar7200Bx it is not working normal
this is my third video still i need help
Old 05-08-2012, 01:36 PM   #3
eddiscus
It looks like to me that the AR7200BX does not output a throttle signal until it (ar7200bx) finishes initalizing. During that first couple of seconds the ESC is looking for a throttle signal and beeping indicating no throttle signal present. Once the AR7200BX is initalized the throttle signal is turned on and the ESC is happy.
The non BX receiver puts a throttle signal out as soon as powered and the ESC has about a 1-2 second lag before it is ready. Since it see's a throttle signal when ready you get the normal beep.
__________________________________________________
Furion 450
Logo 600 with Vbar
, MA Whiplash 90E, SAB Goblin 700, Logo Xxtreme 800 and Banshee #25.
eddiscus is offline        Reply With Quote
Old 05-08-2012, 01:52 PM   #4
ilkeresmer
First of all thank you so much for your helping , but sometimes it is not finding the signal , and it stays in the no signal mod! Did you watch
My third video?
Old 05-08-2012, 01:56 PM   #5
ilkeresmer
is it relevant to cables that i used for making them longer?
Old 05-08-2012, 02:12 PM   #6
felborn
I Get that also if I'm slow to plug in the anti spark thingy, that's the only thing I can think off
felborn is offline        Reply With Quote
Old 05-08-2012, 02:48 PM   #7
ilkeresmer
this is the 4th video and no signal for esc i dont understant why it is happening!!
help please
Old 05-08-2012, 03:46 PM   #8
ilkeresmer
Hey guys i think my ar7200bx is wrong machining product. i did a video for the Helidirect Team. Her is the video.
Old 05-09-2012, 12:56 AM   #9
ilkeresmer
no one knows about this?? and here is my cabling, helppp
Old 05-09-2012, 02:33 AM   #10
ilkeresmer
i think the ar7200bx was broken by the factory because i tried everything, that s my last video, when i touched the cables it s getting the signal some how
Old 05-09-2012, 09:33 AM   #11
alexmit
It looks like the BeastX needs power before the ESC, so set it up to where the BEC can be plugged in first to power the BeastX. I would try to change the connector on the ESC to see if it is faulty, or look at the pins in the end of the BeastX to see if they are loose or bent. If they are loose I would return it for another one.
Atlanta RC Club, The only club inside the city.
SAB USA Field Rep. Canomod USA Field Rep. Pulse Battery USA Field Rep.
alexmit is offline        Reply With Quote
Old 05-09-2012, 12:51 PM   #12
ilkeresmer
i did it everything , but does not worked, i think the throttle channel was factory errored, when i give the power before esc, it works sometimes after about 10 15 seconds later but it is also dangerous
Old 05-09-2012, 12:51 PM   #13
ilkeresmer
AR7200BX does not suits with Scorpion ESC's!!!
Old 05-09-2012, 03:15 PM   #14
alexmit
Or you just have a bad AR7200BX.
Old 05-09-2012, 03:20 PM   #15
felborn
Mine works, 90 føights with that combination and no problems.
Old 05-09-2012, 05:17 PM   #16
ilkeresmer
is it opto or SBEC version?
Old 05-09-2012, 11:55 PM   #17
felborn
SBEC version
