Old 05-09-2012, 10:44 AM   #1
Cascade
Default No stock on 600 bottom plate.. again.
Friend went into the dirt last weekend and broke another bottom plate.
"2 weeks" until the bottom plate comes back into stock.
This is the only part which is available from RCA exclusively, I should have learned after the last time we had 600s grounded for the same thing.
Time to get a few delrin alternatives made.
Cascade is offline        Reply With Quote
Old 05-09-2012, 09:38 PM   #2
corrosionate
Ive been waiting a couple months now since i crashed. I ended up having to glue mine back together and fab an abs plate to reinforce and use zip ties for backup in case the glue pops loose, so my landing skids wont fall completely off. That would be a blade strike landing for sure. It works but its heavy and ugly.
Im thinking of converting it to the narrower align frame parts so spare parts availability wont be as much of an issue again, or i may order an align nitro bottom plate and try to make it work somehow. I wonder if anyone has tried that.... Looks like i would need the aluminum blocks and the plate itself. If i want to mount anything to the plate it may need to be modified.... Or replaced with another material.... Could be worth a shot. Though if i really can get spares in a couple weeks, that would be easier.
Align: 250, 450 Pro v2, 550 v1, Chaos: 600
MSH: Mini Protos 6s stretch, Protos 500 plastic
Compass: Warp 360
B:130x, 300x, 450 FBL
corrosionate is online now        Reply With Quote
Old 05-10-2012, 03:12 PM   #3
Dr. Evil
Default another option...
http://chaoscrewlounge.proboards.com...lay&thread=475
Blade mcpX + Erazor 450 + EXI 450 + Chaos 450 + Chaos 550
Chaos 600 + Chaos 700
Dr. Evil is offline        Reply With Quote
Old 05-31-2012, 01:08 PM   #4
Ah Clem
After a crash last year, I used an Align plastic part with spacers. It worked well until I could get the correct part.
It did not cross my mind to modify the machine to the narrower frame spacing of the Trex 600E, as the additional width, to me, means additional stiffness and strength.
KBDD-Team Pilot
Team Compass / ProStar Hobby
Gens Ace Field Representative
Warp 360, 7HV,Knight Pro,Knight 3D, Atom 500, Odin II, 6HV, 3D Plus, Knight 50
Old 06-01-2012, 04:44 PM   #5
Dajavu*Xion
what happend to that outstsanding customer service I allways seem to hear of ? Just go align
Dajavu*Xion is offline        Reply With Quote
Old 06-01-2012, 06:10 PM   #6
TowPilot
Trolling is not permitted on HF.
The sub-forums are for support of each specific model.
If you hate Toyotas, spend your time in other sub-forums.
Do not negatively impact the support given here.
Mike
TowPilot is offline        Reply With Quote
Old 06-19-2012, 11:08 PM   #7
corrosionate
Go have a look. I found these to be in stock last night. I ordered mine. I did not receive the notification, so for those of you who chose to be notified when the item is back in stock, know that you may not have received your notice either.
Finally! I'll have to go dig my 600 out of the closet now.
Compass: Warp 360
Old 06-20-2012, 09:27 PM   #8
satgod
ebay 18.00
if you have the old one use glass cloth on the bottom side of the plate after ca'ing it back together so it hold while you work
coat the glass cloth in epoxy and apply to the underside (side not in the battery compartment
brush it down and when it dries you can lightly sand it down for a clean finish and fly it forever. If you have the old broken one as well apply the glass cloth then apply the other bottom plate and let dry
problem solve just short of forever
Trex 600EFL Pro V2 V-Bar ds610 ds650 cc pro bec Scorpion 130a HV KDE 600XF-530
450pro 1860kv(6s) cc50 (4 DS215MG) 10t pinion, Tarot DFC, Ikon
TBS Discovery (Quad), naza-gps, 900mhz fpv, gopro2, ET OSD pro, D/L UHF
X-8 Wing , D/L UHF Full fpv package
satgod is online now        Reply With Quote
Old 07-11-2012, 03:41 PM   #9
Dajavu*Xion
= 10 points and a 30 day ban..One must talk/write on rice paper in heli freak !!
Old 07-17-2012, 12:28 PM   #10
paulmedford
I went with the kDE bottom bracket, it's the last bracket you will have to buy and it saves your frames, just use plastic screws on the landing gear. I had a horrible crash and my frame and skids were in one piece. You will spend more in the long term buying plastic bottom plates every time you crash.
paulmedford is offline        Reply With Quote
Old 07-19-2012, 12:11 PM   #11
Luvmyhelis
This is what I was just going to suggest! For one the plastic bottoms are flimsy and poorly made. Whether this model or the Align. It was the very first part on my 600 that I scrapped immediately. I noticed right off the bat the heli was far more rigid overall.
Luvmyhelis is offline        Reply With Quote
