Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Compass 7HV, 7HVU and Chronos
Compass 7HV, 7HVU and Chronos Compass Compass 7HV, 7HVU and Chronos Model Helicopter Discussion
Old 05-09-2012, 09:22 PM   #1
bolus60
Default Tool to remove spring pin thru tail shaft for tail pulley
Look for drift pin tool to remove spring pin 2x14 thru tail shaft for tail pulley
bolus60 is offline        Reply With Quote
Old 05-09-2012, 09:50 PM   #2
BakedMopar
I use a small punch and just tap it out.
BakedMopar is offline        Reply With Quote
Old 05-09-2012, 11:43 PM   #3
Rob43
+1...I also use a 1/16 dia pin punch to tap it out. Try your Ace Hardware. If you don't already have one, while your there, purchase a 4 oz ball pein hammer for tapping it through. 1/16" is just above 1.5 mm dia, so it works perfectly. Clearance fit to the bore size of the thru hole, and easily pushes the pin out or back in. Also works well for the hinge pins on slider mechanism.
= Rb43 =
Rob43 is online now        Reply With Quote
Old 05-10-2012, 08:52 AM   #4
TheBum
I know a few people use an arbor press with an appropriately sized punch. I've considered getting one of those myself.
HeliFreak Support
DT520Ev2 (VBar), Protos Max Evo 700 (Brain), Protos Max V2 770 (Brain2; under construction)
TheBum is online now        Reply With Quote
Old 05-10-2012, 10:44 AM   #5
Dflyer
Just use the back of a 2mm drill and you can tap the pin out without any problems !
Grtz,
Dirk
The heli virus has infected me and i hope that there is NO CURE !! Compass Support Team
__________________________________________________ _____
Warp 360 / 6HVU / CY Stingray / Invertix 400 / SH Little Spyder
Dflyer is offline        Reply With Quote
Old 05-10-2012, 12:04 PM   #6
TheBum
The problem I have with tapping them out is keeping the blasted pulley from turning.
HeliFreak Support
Old 05-10-2012, 08:28 PM   #7
bolus60
Thanks, located a few options to purchase a drift pin kit. I'll start looking for a small press
Anyone know who stocks pins for the 7HV?
Old 05-10-2012, 08:40 PM   #8
Ah Clem
"Anyone know who stocks pins for the 7HV?"
Nankin Hobby has them.
Alan also provided a McMaster Carr part number on the forums, a while back-I cannot recall if it was for the 6HV or 7HV, though.
Old 05-10-2012, 09:36 PM   #9
Mercuriell
Miniature Aircraft do a nice little tool but it's not hard to make something up yourself. Make sure you use a blunt ended driver though otherwise the roll pin opens out when you attempt to drift it. Always best to use a new roll pin too.
John
Mercuriell is online now        Reply With Quote
Old 05-10-2012, 09:50 PM   #10
TheBum
They were for the 500 and the 6HV. I could probably look one up for the 7HV if I knew the length. I assume it's 2mm diameter like the 500 and 6HV?
HeliFreak Support
Old 05-12-2012, 03:22 PM   #11
Diviner
Block of wood . . .$ 0.25
Dental tools from Harbor Freight . . . $3.95
Low frustration level . . . Priceless.
Name:	compass tail jib.JPG
Diviner is offline        Reply With Quote
Old 05-12-2012, 04:54 PM   #12
dunkonu23
LOL! Great idea!
Scott
Team Compass USA--Field Rep
KBDD Team Pilot ):>
www.experiencerc.com: Making Helicopters Great Again!
dunkonu23 is offline        Reply With Quote
Old 05-15-2012, 07:18 PM   #13
bolus60
Old 01-25-2013, 01:26 PM   #14
FlyingBeaver
I'm might be slow, but I'm not sure I understand how Diviner's tool works..
FlyingBeaver is online now        Reply With Quote
Old 01-25-2013, 01:49 PM   #15
flyer2160
i have moded the tail shaft like the thunder tiger raptor 30/50. i have drill the and tapped the tail shat in the end and use a 3mm grub screw to secure a plain 2mm pin through the pulley.
andy
flyer2160 is offline        Reply With Quote
