Go Back   HeliFreak > R/C Helicopter Support > KDS Helicopters and Electronics
KDS Helicopters and Electronics KDS Helicopters and Electronics Discussion
Old 05-11-2012, 01:38 PM   #1
Bjeian
Default KDS 450SV ESC?
Hi!
Got a question about my 450SV:
When I connect the LiPo battery, the ESC goes di,di,di...for about 20 seconds!?!? This happens every time I connect the first battery for the day. Next battery, no more than the normal 3+1 beeps... And yes, the transmitter is ON. At first I thougt it colud be the throttlehold-button, but it makes no difference if its on or off.
The manual for the ESC does not say anything about these beeps, but I've read somewhere else that continous beeps like this, indicates that the ESC is not recieving the throttle-signal form the TX...
When the beeping stops though, everything works great!
Best greetigns from NORWAY!
Bjorn Einar Andersen
Bjeian is offline        Reply With Quote
Old 05-12-2012, 11:15 AM   #2
Clinton1
Yes, mine did the same. First batt just kept on beeping, untill i unplug everything and try again. After a while my esc would just be in IU mode, doesnt matter if the Rx is in normal flight. Took it out and replaced with HobbyWing 40A esc. Since then no problems.
Goblin 630 - Furion 6 - Trex 450 Pro - mCPX
DX 8
Clinton1 is online now        Reply With Quote
Old 05-12-2012, 12:03 PM   #3
Bjeian
Hi there!
What is IU mode? I'm kinda new to this stuff...
Old 05-13-2012, 04:14 AM   #4
Clinton1
Hi - IU is Idle Up mode. That you set on your Tx for different flight modes. That is to set your throttle curve - normal mode is 0-25-50-75-100. In IU it is a flat curve - something like 100-100-100-100-100 or 100-90-80-90-100. That you use for flying 3D that the motor doesnt slow down when you start to use negative pitch for inverted flight. Hope it helps.
DX 8
Old 05-13-2012, 07:17 AM   #5
Bjeian
Ahh...right...just me being stupid there for a second...
I just focused on the ESC and could not figure what IU meant from the ESC-manual
Thanks anyway for clearing that up!
I see you have had the same experience with the beeps, but does anybody know what actually causes this fenomena?
Old 05-31-2012, 05:55 PM   #6
KDS Wes
My KDS 450sv did the same thing. I tried everything to get it to stop. I eventually learned that it was the ESC thinking my throttle was slightly on. I just gave the throttle trim one click down on the TX and that was the last I ever heard of the annoying long winded beeping. Hope it helps you.
TRex 600 EFL Pro Custom CF 450 Heli with Hughs 500E Scale Fuselage, Align Trex 450 Sport ,KDS 450SV, 200mm ZMR Quadcopter, MCPx V2 all aluminum head, MSR Alum swash & grips, Hubsan X4,Blade 120 & CX2 (for my Grandson) all on Spektrum DX8 TX
KDS Wes is offline        Reply With Quote
Old 06-02-2012, 03:15 PM   #7
eddie currents
My KDS450SV did that but the beep wouldn't stop. Eventually found some of the signal wires had chafed against the frame. It was never the same after I sorted the wiring (intermitten power loss during flight) so i changed the ESC. Right as rain now.
Don't really trust the KDS ESC much. The replacement (Black Mantis 40A) seems a lot more substantial for the same rating.
eddie currents is offline        Reply With Quote
Old 06-11-2012, 11:32 AM   #8
Ghostflyer1
It is seeing what it thinks is the throttle in a state above off. You can 1. Drop the throttle seeing using the trim on the radio, or 2. you can pull the blades off *tail included* and recalibrate your throttle endpoints so that it will behave properly. Its a standard procedure on the Castles these days.... Hope this helps.
GhostFlyer1
KDS Dual Innova 700's, Innova 450,, and to many others to list
Ghostflyer1 is offline        Reply With Quote
Old 06-13-2012, 10:29 AM   #9
Bjeian
The trim procedure sounds logical...I will try it and tell you how it went!
Thanx
Old 06-18-2012, 02:33 PM   #10
NJflya
Your throttle trim is too high turn it way back it's not needed anyway the throttle speed is controlled by your throttle curve.
NJflya is offline        Reply With Quote
