Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 7HV
Atom 7HV Compass Atom 7HV Model Helicopter Discussion
Old 05-11-2012, 09:00 PM   #1
Rob43
Default Got 115's?
I just fitted a set of Rotor Tech 115mm tail feathers today. Excellent blades. Flew great. If it wasn't as windy, and I had more time, I'd have tested the hurricane to funnel move to see if it held at low headspeed. Next time.
I just heard from JamesPPP that his kit came with Compass 115's...Uh?
= R
b43 =
Team Compass Support
Rob43 is offline        Reply With Quote
Old 05-14-2012, 09:04 AM   #2
Mr Nice Guy
I run Edge 115s on mine and they work at 1700 and below and up to 2000+. Tail really holds well. I like them a lot.
Knock on the sky and listen to the sound
Mr Nice Guy is offline        Reply With Quote
Old 05-23-2012, 03:35 PM   #3
Rob43
Tried them beyond 2000 headspeed? Mine need to have the gain reduced at the higher speeds, but are superb so far.
= R
b43 =
Old 05-23-2012, 08:20 PM   #4
lazor 22
My kit came with what look like 110's, size is right in between the edge 115 and the kbdd 104 i have
Compass, ProStar Hobby, Giant Power, OnlyFineHelis, Protek/Amainhobbies
7HV, Warp, 3D+
Lincoln
lazor 22 is online now        Reply With Quote
Old 05-23-2012, 08:55 PM   #5
Rob43
Yeah, JamesPPP reported the same thing. I thought also he said they were plastic...?
= R
b43 =
Old 05-23-2012, 09:20 PM   #6
lazor 22
Yea yellow plastic
7HV, Warp, 3D+
Lincoln
Old 05-23-2012, 10:38 PM   #7
BakedMopar
That could just be the old blades as mine from the first batch was a bit bigger than the KBDD 104's.
I was going to get 115's for mine but I didn't know if the tail could handle it.
BakedMopar is offline        Reply With Quote
Old 05-23-2012, 10:45 PM   #8
Rob43
Fair question, BakedMopar. I am running the RJX grips, so I didn't think it would be an issue in my case. JamesPPP said the blades in his kit are plastic 115mm blades.
= R
b43 =
Old 05-23-2012, 10:46 PM   #9
lazor 22
My kit is from the batch 2 weeks ago
7HV, Warp, 3D+
Lincoln
Old 05-23-2012, 10:51 PM   #10
Rob43
So they are indeed larger than the original tails, I guess.
I only needed bigger tails for running low headspeeds from my experience. The Rail 106's work fine if I am spinning >1900 rpm.
= R
b43 =
Old 05-23-2012, 10:52 PM   #11
BakedMopar
Care to post some pics Lincoln? I would love to see the evolution of this heli.
Rob I'm using the stock tail so you see why I have my doubts.
Old 05-23-2012, 11:13 PM   #12
lazor 22
I'm not really familiar with the 7HV kits before mine so can't say what I've noticed that has changed but I posted some pics in the pics and videos thread. One thing though is mine came with a nice sturdy black and white blade holder (don't like the older flimsy yellow)
7HV, Warp, 3D+
Lincoln
Old 05-23-2012, 11:18 PM   #13
BakedMopar
I meant the tail blades.
Old 05-23-2012, 11:21 PM   #14
lazor 22
Oh they just look like bigger versions of the 6hv/3d plus tail blades
7HV, Warp, 3D+
Lincoln
Old 05-24-2012, 05:28 AM   #15
Rob43
Black & white blade holder? Really. Plus, the yellow shows everything too. Even makes my butt look big when I carry the heli.
= R
b43 =
Old 05-24-2012, 09:07 AM   #16
Jamesppp
Rob, I put the scale on the yellow blades that came in my kit, which should be from the latest batch, and they are not 115's. I think about 112mm or a little more from the center of the bolt hole to the tip. When measured that way the line is on a bit of a diagonal from the leading or trailing edges so probably they are called 110's
Compass7HV,Sk720HeliJive120HV Pyro 700 52L allHV
Outrage 550: Scorpion 4020-1390,CC125A ESC,WR ESC
Logo 5003D Scorpion Sk720 4020-1100, Blade130X MCPX
TT E-620 SE x 2: Scorpion 4025-740 CCHV85 ,770/8900
Jamesppp is offline        Reply With Quote
Old 05-24-2012, 10:21 AM   #17
Rob43
OK. That should be a nice blade. Either of you have a pic?
= R
b43 =
Old 05-24-2012, 10:48 AM   #18
lazor 22
Those are with edge 115
7HV, Warp, 3D+
Lincoln
Old 05-24-2012, 06:26 PM   #19
BakedMopar
Those look like they are the old blades then.
