Old 05-14-2012, 08:24 AM   #1
fuzzyllamma
Default Tail blows out on hard punchouts
I was doing some inverted punchouts today and at dropping the stick hard, the tail would completely pirouette out of control for a few seconds (first piro flip! ). I suspect that my problem is either bad tail bearings or my futaba 9257. I already replaced my tail bearings with the boca replacements and i have the futaba gears on order (some of you may remember my earlier thread on a "clicking" noise). As far as i know, the tail is not binding in any other spot. Is there anything else that could be causing my issue? I am using the ar7200bx and it has been working flawlessly except for recently in ff flight, the head will bob and tail will wag. I know that decreasing cyclic gain and tail dynamic will probably fix this, but it has been doing fine up until the tail blowouts. Would the bad tail cause the head bob?
fuzzyllamma is offline        Reply With Quote
Old 05-14-2012, 07:02 PM   #2
dl5973
have you tried the inverted punshout before?
does this happen with upright hard stick punchouts?
dl5973 is offline        Reply With Quote
Old 05-14-2012, 08:37 PM   #3
fuzzyllamma
Yeah i have done them before. Its only recently that it has started acting up. I cant get it to do it in upright orientation. Am i using too much pitch and stalling the head maybe?
Old 05-14-2012, 08:38 PM   #4
fuzzyllamma
15 degrees of negative*
Old 05-14-2012, 10:42 PM   #5
Wolfpackin
Could be, depending on collective management and headpeed.
I'd start by trying lower collective pitch and high headspeeds, see if that helps.
Also look for anything slipping in the tail system when torqued.
Zen and the Art of Helicopter Maintenance
Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.)
CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG.
T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades.
Wolfpackin is offline        Reply With Quote
Old 05-15-2012, 09:21 AM   #6
Starcruiser
reset the collective range to make it symmetrical, i.e. + 13° and - 13° (or whatever range you prefer). the -15° is too much IMO thus causing the blow out. You could also check your governor (if you are using one) or if not then change up the throttle curve to a mild "V" to increase head-speed to avoid the bogging.
Carl
Trex 550E FS Vbar Pro 5.2- EXI-450T Mini Vbar Pro 5.2 - EXI 450T BeastX - Trex 250SE - mCPx v1 Hp05 & HP06 w/HP03t tails - AMA #952544
Starcruiser is offline        Reply With Quote
Old 05-15-2012, 10:39 AM   #7
fuzzyllamma
Im already running 3500 hs governed with my scorp -6. I do have it symmetrical at +-15. Ill change it up and see if i can replicate it. Thanks for the input guys.
Old 05-15-2012, 02:09 PM   #8
Starcruiser
I run a Scorpion -6 on one of my 450's too and it likes to blow out for a 360 or so on hard collective input. I am playing with the governor (CC ICE 50) to see how I can minimize it. I run at +/-13° so on a hard punch out it will lose it, tweaking the governor gain has reduced it but the -6 is a torque monster. I also reduced the head speed to about 3k (I was running it at like 3400 prior).
I am running a 13T pinion, 2200mAh Hyperions 35c with a Vbar Mini Blue and a ICE 50 w/heatsink in fixed RPM mode.
Carl
Old 05-27-2012, 01:31 PM   #9
fuzzyllamma
I changed a couple things - flipped the grips and also turned on the tail precomp on the beastx. Seems to have remedied the issue it twitches a little bit if i punch it really hard but it is nothing that i am really worried about. Thanks for the suggestions.
