Old 06-15-2012, 07:46 PM   #61
Dylwad
Originally Posted by rossk View Post
I read somewhere that the 6S setups have been measured pulling up 37amps, so most connectors would be fine.
I am using EC3, which are rated for up to 60amps!
Keep an eye on those EPbuddy EC3's, I ended up swapping mine out for XT-60's, the EC3's became far too easy to unplug after a while, you could flick the connector and they would fly apart. Performance increased after the swap too.
I had EC3's on my RX pack on the 7HV as well, and swapped them for Multiplex 6 pin connectors.
Dylan
Dylwad is offline        Reply With Quote
Old 06-15-2012, 10:08 PM   #62
rossk
Roger, will do, they are still new, so pretty snug
rossk is offline        Reply With Quote
Old 06-16-2012, 02:59 PM   #63
red_1030
Went to set up electronics this after noon and ran into some problems. first off the program card; i plugged everything in per the instructions and the card liit up as described. at this point i decided to read through all the instructions first so i disconnected, read through the instructions and connected everything back up and now nothing....no lights or tones from the card just one solid light on the esc.
figuring the card is now bad I decided to stick program the esc through the transmitter (dx6I). So I reconnected motor/esc to the AR7200BX I bound the bx no problem and servos were active, I bumped the throttle stick and the motor chattered and began to smoke, I immediately disconnected power. Looked everything over, the frame is scorched at one of the motor mount bolts and at the top by the battery tray F@%&!!!! Figgured the polarity was wrong on the motor I switched two of the wires and tried again seems to work fine now Why the F&*@% don't they color code the wires on the esc and motor?. I tried the program card again and nothing. The YGE instructions are horrible and it looks like i only get default settings. I wanted to run in gov mode so I guess i need to order a new program card . This is extremely frustrating as i now have a 1K paper weight.
Trex550 AR7200BX, B450X
red_1030 is offline        Reply With Quote
Old 06-16-2012, 03:03 PM   #64
Thalios
They don'T color code them as polarity doesn't matter. It's a 3 phase motor. Any wire combination will not smoke the motor. You have something else wrong here.
Lynx Heli Team Pilot
Prôtos CF, 130X and many others.
CarbonCore H6 650mm Wookong-M
All on DX18!
Thalios is offline        Reply With Quote
Old 06-16-2012, 06:20 PM   #65
rossk
It definitely has nothing to with the 3 wires on the motor and they do not need to be labelled, I like this simple explanation from mr mel:
Make sure you are not shorting the motor by having the bolts too far into the motor...
Old 06-16-2012, 06:53 PM   #66
red_1030
That's a good video! I did learn a few things from it. My theory of why the motor smoked is because I obviously had the motor direction reversed, but the motor couldn't turn because of the one-way bearing so it got hot and smoked. After switching the two wires the motor spins in the right direction but I'm concerned about residual damage to the motor or esc. my prog card is burned up too so I can't prog the esc, I'm sure changes need to be made. I.e. throttle calibration, 6s motor setup?
I'm also gonna check the seggestion about the motor mounting bolts shorting the motor. I did notice a lot of heat in the mount.
Sent from my iPhone
Old 06-16-2012, 07:33 PM   #67
red_1030
Here are a couple pics of the frame damage and prog card:
This is at the battery tray next to the rubber band mount.
This is the rear motor mount bolt on the right side
I think this is the burned spot on my prog card, can anyone confirm?
Sent from my iPhone
Old 06-22-2012, 01:58 PM   #68
red_1030
Ordered a new prog card, should get it today. Hoping the card failure was a fluke, if not out withe the yge and in with the ice lite 50 sitting in my 450 3D.
Sent from my iPhone
Old 06-22-2012, 06:32 PM   #69
SMJT
Attachment 325082
Attachment 325083
Attachment 325084
Sent from my iPhone
That is not a burn spot my card is like that
mini PROTOS
GAUI X2
GOBLIN 500
SMJT is online now        Reply With Quote
Old 06-22-2012, 07:55 PM   #70
th0rg0d
Sent from my iPhone
I know you gots to go with what works for you... But blasphemy!
I hope you get the YGE sorted.
Mini Prôtos AR7200BX
Prôtos stretch AR7200BX Savöx 1250/1290MG SAB 470mm
ALeeS Rush 750 YGE 120HV/4035-530 AR7200BX Savöx 1258/1290MG Rail 696/116
mCPx stretch uHeli head DX18 AMA# 448427
th0rg0d is offline        Reply With Quote
