Go Back   HeliFreak > R/C Electronics Support > Spartan RC
Spartan RC Spartan RC - Quark, DS760 Gyros and other Spartan RC Electronics Factory Support
Old 05-15-2012, 05:45 PM   #1
blockmason
Default spartan querk gyro direction problem?
I just finished building trex 450 sport v2 kit. I set up my gyro according to finless video. I attempted to spool up and I got a bad spin as soon as it was lite on the skids. I went back and rewatched the video. I did have the servo travel correct but the gyro does not want to correct in the right direction. I am using a dx6i a hitec 5084mg servo on the tail. I have the servo hanging on the tail. And reversed in the servo menu. Any ideas would be GREAT!!
blockmason is offline        Reply With Quote
Old 05-15-2012, 06:02 PM   #2
johnsma22
You have to go into setup mode in the quark gyro and change the gyro correction direction.
johnsma22 is offline        Reply With Quote
Old 05-15-2012, 07:20 PM   #3
blockmason
I did that but it still is not right.
Old 05-16-2012, 04:37 AM   #4
Angelos
Please see here: http://www.spartan-rc.com/resources/faq/faq.php?topic=6
Also ensure that when you set up the reversing and endpoints you reach the end of the process (LED steady on) as only then the adjustments are saved.
-Angelos
SPARTANRC - R&D
Angelos is offline        Reply With Quote
Old 05-16-2012, 04:55 AM   #5
BavarianRob
Try reversing your gyro on your TX, worked for me.
BavarianRob is online now        Reply With Quote
Old 05-16-2012, 03:50 PM   #6
Abenn
I got a bit confused in my Quark setup the other day and, when I was in the gyro direction menu I was giving it left rudder and then right rudder, thinking I had to see the tail slider go to both extremes (like when setting the limits). That's not the case -- left will give you gyro normal and right will give you gyro reverse (or is it the other way round?), so by moving the stick both ways I was cancelling out what I'd just set
Abenn is offline        Reply With Quote
Old 05-16-2012, 09:38 PM   #7
blockmason
thanks angelos and abenn. I did the same thing as abenn did and went both ways. I had t reverse my rudder channel. Only after watching finless video two more times did I catch the fac if I reversed the servo I had to move the rudder stick to the right instead of the left and right. And I did not go through the whole setup till I got the solid light. It seems to work great. Just need to finish setting the gains up. Thanks!
