Old 05-17-2012, 02:03 PM   #1
ImperatorMagnus
Post Calling All MSH Protos Owners...
I am looking for information on your opinion on your Protos. The Pros and Cons. Advice, suggestions, build ease, repair cost vs. other brands, etc. I am looking to obtain one in July during my vacation.
I would also like to know your setup (spec wise, motor, esc, bec, servos, etc.)
Semper Fi,
Gunny.
ImperatorMagnus is offline        Reply With Quote
Old 05-17-2012, 02:05 PM   #2
ImperatorMagnus
Default Calling All MSH Protos Owners...
Semper Fi,
Gunny.
Old 05-17-2012, 02:22 PM   #3
Dr. M
I love my Protos!
Pros: Flies awesome, lightest 500-class bird, low parts count, single-belt design (super quiet and resilient), inexpensive and readily available parts, available stretch kit.
Cons: tail setup can be finicky, stock canopy colors can be hard to see at distance.
Fly first ask questions later.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
MSH PRÔTOS 500 FBL "Sky Whip" | ZYX v4.0
Audacity P6 FBL "Phoenix" | MSH Brain | 12s e-conversion
Dr. M is online now        Reply With Quote
Old 05-17-2012, 02:51 PM   #4
shadco
Gunny
Everything ^^ said.
Slightly smaller than a Trex 500.
Cons
Don't react well to the use of Align Hold Down straps.
I will be getting a Mini P soon.
Oh and thanks for your service.
Synergy E5-S KDE 600XF MKS HV YGE Vbar : Compass 6HV Quantum 4125 MKS HV YGE Vbar
SAB G500 Savox 4050 KST/MKS HV YGE HC3SX
Compass Warp Scorpion 2520 MKS YGE SK540 : 130X MCPX BL Nano 14SG DX8
shadco is offline        Reply With Quote
Old 05-17-2012, 04:00 PM   #5
Clay333
Nicest 500 size heli period. Just grab the combo with the scorpion motor and YGE esc and you will be set. The Protos is a very simple heli that flies awesome.
Clay333 is offline        Reply With Quote
Old 05-17-2012, 04:27 PM   #6
ImperatorMagnus
Hahahaha. Really? Thanks for your input. She is a sexy looking bird for sure.
Semper Fi,
Gunny
Semper Fi,
Gunny.
Old 05-17-2012, 04:28 PM   #7
ImperatorMagnus
Originally Posted by shadco View Post
Gunny
Everything ^^ said.
Cons
Thanks for your input. I like the pic. Thank you and the the pleasure was all mine. I enjoyed protecting all of our freedoms.
Semper Fi,
Gunny
Semper Fi,
Gunny.
Old 05-17-2012, 04:30 PM   #8
ImperatorMagnus
Thanks Clay. She is a sexy bird. That is the one that I am going to get. Do you have one? What's your setup like?
Semper Fi,
Gunny
Semper Fi,
Gunny.
Old 05-17-2012, 04:33 PM   #9
ImperatorMagnus
Gentlemen, could you expand further on your setup? What servos do you use or recommend? Which ESC, BEC if you do? Gyro? Don't be afraid, Gunny don't bite!
Semper Fi,
Gunny
Semper Fi,
Gunny.
Old 05-17-2012, 04:34 PM   #10
ImperatorMagnus
Semper Fi,
Gunny
Semper Fi,
Gunny.
Old 05-17-2012, 04:56 PM   #11
BurritoSnake
I don't own one yet either as I am planning to have one between now and winter but if you are in a rush then just do some forum searching as your questions will be answered. I know mine where by reading through the threads as there are a lot of different build and vs threads.
BurritoSnake is online now        Reply With Quote
Old 05-17-2012, 05:04 PM   #12
Clay333
Mine is setup with Futaba 9650 cyclic servos, Outrage OS7654T tail servo, Beastx Flybarless controller, Stock Scorpion 880kv motor, stock 60amp yge esc, running flybar Radix blades, but my set of FBL edge blades should be here tomorrow or Saturday. I owned a Trex 450 Pro before the Protos, and can honestly say that the Protos is miles ahead of the Trex.
here is a link to my setup. I have since upgraded the Align ESC and Lipotech motor to the Scorpion and YGE.
Old 05-17-2012, 05:42 PM   #13
wbefield
Here is my setup:
Protos 500 CF
YGE 60A
SAB 425mm-Stock Blades
Scorpion 880KV Motor
KBDD Tail Blades
Flybarless Upgrade Kit
BeastX
AR6210 Receiver + Satellite
Futuba S9650 on Cyclic
Spectrum H6080G Tail Servo
Gens Ace 2500Mah 6s 25c Lipos
Here is the link to my build thread from January.
http://www.helifreak.com/showthread....ield%27s+build
William
Alees Rush 700-Kosmik 160A + KDE 700XF-495
Synergy N5C & E5-600
Protos 500
wbefield is online now        Reply With Quote
Old 05-17-2012, 07:33 PM   #14
Slyster
There is a protos forum where you can get as much info as you could ever want http://www.helifreak.com/forumdisplay.php?f=122
It's not just a hobby... it's a lifestyle!
Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo
Pete Team Outrage.
Slyster is online now        Reply With Quote
Old 05-17-2012, 09:04 PM   #15
ImperatorMagnus
Thank you for the info gentlemen.
Semper Fi,
Gunny
Semper Fi,
Gunny.
Old 05-17-2012, 09:26 PM   #16
Mr dan
Protos 500:
Scorpion HK-3226-900 w/ 15t pinion
Savox SH-1250 MG cyclic servos
MKS-BLS 980 Tail servo
Micro BeastX V3
AR 6210X rx w/ sat
Castle Creations Ice 75A ESC
Caslte creations 10A BEC
Castle creations Quick link
Mavrikk G-5 pro mains 430mm wide cord
KBDD yellow and orange 70mm tail blades
Voltz 2650 45C 6S lipos (2)
Voltz 2650 35C 6S lipos (2)
Sky lipo 2650 40 C lipos (3)
DX6i DSMX transmitter
Mr dan is offline        Reply With Quote
Old 05-17-2012, 10:21 PM   #17
ImperatorMagnus
Originally Posted by Mr dan View Post
Protos 500:
Micro BeastX V3
AR 6210X rx w/ sat
OUTSTANDING setup. Or as in the Corp., Loadout!!!
Semper Fi,
Gunny
Semper Fi,
Gunny.
Old 05-18-2012, 05:13 AM   #18
kavic5150
Post
Got the tarot gy650 mems gyro w/a inolab d261hb tail servo. 3x hitec hs5245mg and stock motor/esc/SAB blades on the full carbon kit.
Man this thing is a blast to fly. It handles with surgical precision, no slop atoll.
Do recommend the hs5245mg, they are super smooth high resolution servos. The inolab is ok but could be a bit quieter, you could probably do better. And for $53 the tarot gyro is great, but I dont think its on par with a quark from what I've read.
Take your time on the build, laugh at Finless Bobs jokes in the build vids.
Its a surprisingly low maintenance bird too. Just keep those bearings lubed, especially those belt pulleys.
Hoss X4e 6s, Gaui 550, Protos 500 12s, Losi Speed-T.
Save the flybar !!
kavic5150 is offline        Reply With Quote
Old 05-18-2012, 11:06 AM   #19
Dr. M
Probably the best way to own a P500 is to find a nice used one on the FS forum; especially if you wanna go FBL and don't like the idea of buying a FB kit + FBL upgrade right off the bat.
Mine is a cf frame, stock 880kv motor and SAB blades, CC Ice Lite 75, Align ds510 cyclic, mks ds760p on tail, CopterX 3x1000 fbl controller, AR6210 + sat, thrusted tail upgrade. Powered by Gen Ace 2600 6s.
Old 05-18-2012, 11:14 AM   #20
ImperatorMagnus
Good advice Dr. M. I am not fond of the FB. I am not opposed to upgrading either. The only issue that I see is that the Protos, at least I haven't seen in the few months that I have been trolling the forums, don't come up all to often. The good thing is that I am in no rush. Push comes to serve I'll purchase the Protos fly her a bit and decide the FBL route later.
Semper Fi,
Gunny
Semper Fi,
Gunny.
