Go Back   HeliFreak > R/C Helicopter Support > Outrage Velocity 50 Nitro
Outrage Velocity 50 Nitro Outrage Velocity 50 Nitro Helicopter Factory Support Forum
Old 05-18-2012, 04:59 AM   #1
Stevin
Default Cyclic pitch ball link upgrade
Found this on helidirect, http://helidirect.com/r50n981-ss-out...50-p-15727.hdxthey look to be longer then the stock balls on the swash, the pictures looks almost like the ball that is on the tail control rod link pivot where the boom meets the frame. I assume they ould be used on the swash plate for the pitch control links?
Avant E-Aurora FBL Vbar 5.3pro / Trex 450 pro vbar 5.3pro/ Velocity50 Vbar 5.3pro / Trex 600efl PRO Flybarless vbar/CC HV80 / Brushless Blade MCPX / Outrage 550 VBAR5.2Pro/ICE100
Stevin is offline        Reply With Quote
Old 05-18-2012, 07:06 AM   #2
rotor head33
thats what i thought originally but wouldn't it hit the swash plate itself?
velocity 50- Total G
rotor head33 is offline        Reply With Quote
Old 05-23-2012, 06:42 AM   #3
RotaryBliss
have a look at this: http://www.helidirect.com/Manual/R50N981.pdf They go on the mixing arm, not the swash..
RC field rep.
Team Tail-in / Helifreak Elite Bacon Awareness Committee
RotaryBliss is offline        Reply With Quote
