Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 7HV
Atom 7HV Compass Atom 7HV Model Helicopter Discussion
Old 05-18-2012, 09:10 AM   #1
uragano47812
Default Helical main gear and upgraded tail
Sebastian is working on this 2 upgraded parts as you can see from the last video on the tube.
Anyone can confirm and any ETA?
Compass 7HV - Vstabi 5.3Pro
Trex 600 EFL Pro - MiniVstabi 5.3Pro
MiniProtos 3s - MSH Brain
uragano47812 is offline        Reply With Quote
Old 05-18-2012, 09:40 AM   #2
GimpyGolden
Sure is quiet with the H-gear compare to the current straight cut.
Lot's of tail noise too, maybe gain is too high for 2050 to be high enough for 1100hs. BX has no bank switching as in V-Bar.
Scott
RC
HeliCanada.com
-Rep
Compass 7Hv - Synergy E5 - Logo 600
Next: 6Hv Ultimate
GimpyGolden is offline        Reply With Quote
Old 05-18-2012, 09:47 AM   #3
Mixmaster Pilot
Was that last IU 1100? Damn that sounded quite! I'm guessing 115 tail blades on the new tail?
Yeah I think the gain was too high for the reasons you said Gimpy. Makes me glad I have the GY750 and 8FG combo on my 7HV for this reason. My 450 has the BX.
Edit, and nice landing gear strut "test" at the end Sebastian
Compass Atom 7HV, Scorp HK3 4035 hand wound by Mauro - 6x7x1.32 YY 430KV, CGY750
Beam E4, 6S, looking for a new FBL unit, BX is getting removed!
Formerly owned - Blade mCP X V2 - Blade 400 FBL BeastX
Mixmaster Pilot is offline        Reply With Quote
Old 05-18-2012, 09:59 AM   #4
alexmit
I find this very interesting because the helical gear must be CNC. It is also interesting because Compass/Sebastian is listening to the requests of the masses. I seem to remember at one time that Sebastian spoke against using a helical cut gear. There must have been enough requests or he changed his mind. Either way, having options like this is nice. It all sounds good and I hope to see these parts soon.
Atlanta RC Club, The only club inside the city.
SAB USA Field Rep. Canomod USA Field Rep. Pulse Battery USA Field Rep.
alexmit is offline        Reply With Quote
Old 05-18-2012, 10:11 AM   #5
Caleb White
I saw the helical on Dave K.'s last weekend. It was black Delrin... beefy and yes, quieter! Compass also made the pinion. No idea on ETA to distributors.
Compass Model | KBDD | MKS Servo | running Beast X and Airtronics
Caleb White is offline        Reply With Quote
Old 05-18-2012, 10:13 AM   #6
GimpyGolden
Any idea if it's same tooth count and what pinion size was?
Scott
RC
HeliCanada.com
-Rep
Next: 6Hv Ultimate
Old 05-18-2012, 10:33 AM   #7
Caleb White
Not sure. The guys testing would have to answer.
Old 05-18-2012, 10:34 AM   #8
apostolosnt
I just had this cut. Quiter and smoother. Alloy pinion. Same tooth count. Waiting for compass motor to fully test this. Stock has a good tooth shape so it works very well for a spur gear.
BTW helical can be molded. Mikado does a great job with that on their double helicals.
Logo 600SE, Atom 7HV
apostolosnt is offline        Reply With Quote
Old 05-18-2012, 12:55 PM   #9
TheBum
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
I've always wondered what a helical gear does to the motor bearings. Wouldn't it put extra thrust loads on them and shorten their service life, especially on these high-torque motors?
HeliFreak Support
Nankin Hobby Field Rep, Compass Support Team
Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX
Experience is something you obtain only after you need it.
TheBum is offline        Reply With Quote
Old 05-18-2012, 02:18 PM   #10
sandro12321
Yes, they do, but that's why everyone started putting counter-bearings for the motor shaft. It was for this and the ridiculous torque newer motors produce also. Does anyone know when these helical gears are coming out? That is the only thing i don't like about my compass is the regular cut gears. The tail is fine, don't know why everyone hates plastic so much.
Logo 500 SE,Logo 600 SX, Trex 450 DFC Pro V2, Compass 7 HV, All Vbared on DX-7
sandro12321 is offline        Reply With Quote
Old 05-18-2012, 02:45 PM   #11
alexmit
I'm not sure that is the main reason why everyone put counter-bearings in. Counter bearings were introduced more for maintaining consistent gear mesh under heavy load and as a side effect helped out with the motor bearing issues. I think Bum is talking about the vertical forces on the bearings in the motor due to the screw-like shape of the gear meshes. In other words, a helical gear might introduce forces on 2 axes. The pressure pushing away from the gear, and then vertical forces on the pinion and main gear. I'm not an engineer, so I can't answer about the vertical forces or how significant they might be.
Old 05-18-2012, 02:54 PM   #12
sandro12321
I understand what your saying and it makes sense, but I have over 100 flights on my trex 500 and Gaui X5 and bearings are still good on both. Both have Scorpion motors, so I wouldn't worry about it too much. But when are they coming out? does anyone know?
Old 05-18-2012, 03:03 PM   #13
alexmit
Ooooh, Ooooh... I can answer that before the Compass Reps... hehe
"When it is ready"
Old 05-18-2012, 03:06 PM   #14
Sebastian Zajonz
Hey Guys,
today we did some further testing and also videos. One of Daniel Jetschin flying my 7HV with helical gear and new tail and doing some really technical flying. We also did some hardcore testing with 2400 RPM and it seems to work pretty good in over 40 flights now.
Its 127T and 14T Pinion and new Compass Motor 4926 510KV.
It will be CNC in stock. Bad news - price will be a little high because of the material and CNC time etc.
Effencie of a helical gear is allways not as good as a straight one, but thats about 4%.
The Heli runs smoother - true. I can only feel effencie in motortemperture (about 5-7°C more temperture in average).
Motorbearing doing well. Helix direction was chose to press against the counterbearing. I placed a small washer between pinion and counterbearing and reduced motortemperture about 3-4°C.
Today I did some flying with 1000 RPM - funny you can just hear the blades anymore Tailupgrade with 115mm CF Compassblades works awesome in this headspeed.
Greetings
Sebastian
Team Compass Model - Kontronik - Rapicon - MTTEC - KBDD - MKS
Sebastian Zajonz is offline        Reply With Quote
Old 05-18-2012, 03:11 PM   #15
sandro12321
Sebastian, any idea on release date? are we talking next month, end of summer?
Old 05-18-2012, 05:28 PM   #16
TheBum
Contact between the pinion and the inner race of the counter-bearing via a washer would be a good approach to lessening the thrust forces. The thrust forces would be spread between the counter-bearing and the bearing opposite the pinion (I guess that would be the top bearing the way the motor is mounted in the 7HV).
Any plans to do helicals for the 6HV?
HeliFreak Support
Old 05-18-2012, 07:35 PM   #17
dunkonu23
I love it! Such quiet. Any chance the new tail and gears might be available during flying season? Just anxious, that's all.
Scott
Spartan Vortex VX1 Inside
Team A Main Hobbies/ProTek Field Rep
dunkonu23 is offline        Reply With Quote
Old 05-18-2012, 07:44 PM   #18
Rob43
+1. Same here. Think of it Seb. I bought one of your very first helicopters and flying one of your first production motors. Only fitting I am near the front of the line to get a chance to fly a new Compass tail and gear. Is the sound a primary driver for a new gear? The original seems to work fine.
= R
b43 =
Team Compass Support
Rob43 is offline        Reply With Quote
Old 05-19-2012, 12:11 AM   #19
Stolla
c n c is very expensive, why not just mold it as with raptor e 720 and make it a stock item, we all know helical is the way to go!. The route followed now will make the compass more expensive than some very good machines out there once tail and gears are upgraded. Already just the tail upgrade made my compass cost the same as my e 720, and that is an awesome machine
Old 05-19-2012, 12:35 AM   #20
Cullen Colapietro
In regards to gain, I have a DX8 for example. I can set different gains to each flight mode, which would allow me to run 2 vastly different HS. I would find it hard to believe that there are not other radios out there with the same feature.
6HV|Warp 360| Compass Models | Prostar Hobby | MKS | EP Buddy | Team KBDD
Cullen Colapietro is offline        Reply With Quote
