Old 05-19-2012, 04:05 PM   #1
vmalpi
Default Boca bearings
Is this the correct bearing for main shaft for a 500ESP ?
http://www.bocabearings.com/productD...px?ItemID=3135
vmalpi is offline        Reply With Quote
Old 05-21-2012, 12:38 AM   #2
xpftp
that bearing has a 1 rating for abec or whatever it is ... i think thats the lowest on the scale and is not good... i think the higher the number the better the bearing is ..
i put abec4s in a brushless motor thinkin wow i got a awesome deal on them .. 4 races they was toast ..
but i could be wrong on the numbers ..
i have a set of traxx bearings from a slash or whatever it was that uses them .. they have blue seals on them .. working great so far .. and was good price ..
B400 gotta love the old girl / 250 / 500 ..
Turn Up The Juice. See What Shakes Lose
xpftp is offline        Reply With Quote
Old 05-21-2012, 07:18 AM   #3
nmdesertracer
Those look correct. A smaller class number means a tighter tolerance and a larger number means a looser tolerance. This is just the opposite of the ABEC system.
Juan Martinez for President!
nmdesertracer is offline        Reply With Quote
Old 05-21-2012, 03:24 PM   #4
xpftp
right so if the abec number is lower the bearing isnt a good one .. the higher the number in abec is better ..
the abec number for that bearing is 1 ..
and i think its on a scale of 1 to 14 or something like that
Old 05-21-2012, 03:46 PM   #5
torpedoarmed
Just remember that ABEC does not indicate quality or smoothness. It is a tolereance scale. Figure that one out
torpedoarmed is offline        Reply With Quote
Old 05-22-2012, 07:30 AM   #6
nmdesertracer
1 on a abec scale would be a loose tolerance.
Old 05-22-2012, 12:24 PM   #7
skered53
That's about the cheapest bearing they sell !
http://www.bocabearings.com/bearing-...CYZZNB2-8x16x5
This one has ceramic balls and will run great, very low rolling resistance. $ 7.95
http://www.bocabearings.com/bearing-...R688ZZ5-8x16x5 this one is rated ABEC 5 for a $ 8.95
T-rex 500FBL BeastX, I2 MRH & Swash, I2 tailboom holder TT version,( Bob's the Mahn ! ) DX7s. Gaui 550 FB, T-rex 550 I2 FBL head.
CH-53E's 83-87. MCAS New River. FAA certified Airframe & Powerplant license holder since 1992
skered53 is offline        Reply With Quote
