Go Back   HeliFreak > R/C Helicopter Support > Multi Rotor Helicopters
Multi Rotor Helicopters Multi Rotor Helicopters Info and Support - Tandem, Quadcopters, Tricopters, Octocopters, and Hexacopters
Old 05-21-2012, 04:58 PM   #1
helionfire
Default naza assistant help
hey, ive got my naza assistant downloaded, but mc output on is flashing, so i cannot program my flamewheel, what am i doing wrong??
helionfire is offline        Reply With Quote
Old 05-21-2012, 07:10 PM   #2
patrick21x
Make sure to download and install the Drivers correctly. That has been the cause of most peoples problems connecting to the assistant.
This video may help.
https://vimeo.com/39061642
DJI, DROIDWORX , PHOTOHIGHER, ZOAR, DEALER
AERIALMEDIAPROS.COM
patrick21x is offline        Reply With Quote
Old 05-22-2012, 03:20 AM   #3
petedee
So how did you go with this?
Any luck?
DJI Naza 330, 450 & 550 hexa, TBS Discovery (Naza-M/5.8Ghz vid link/ET telemetry), KK2 micro hexa and micro quad, Nano Ladybird/Spektrum Hybrid, Nano MQX hybrid.
300X, Trex 450 Pro DFC, mCP X's, mSR X, nano CP X
DX18, 14SG
petedee is offline        Reply With Quote
Old 05-23-2012, 01:16 AM   #4
helionfire
ok, finally loaded the driver properly, did the naza setup, pretty easy, just tested it out(no props)first thing, no light on the power module unless i put it in atti, then a flashing red light, is that normal? when i armed the motors, (sticks down and left /right no responce, i had to repeat 3 times to arm the motors, should i increase the throttle trim? i know, im almost there, i learned long ago, patience is a virtue, i would not be half this far without good people like you guys on this forum
Old 05-23-2012, 01:36 AM   #5
sugs
At this point you basically have to make sure all the trims are correct. When you click start and do the stick calibration in Naza assistant, centered positions should result in green slide indications for all four. If not, then adjust the trims on the radio. Then on your control mode switch, when you flip your gear lever, it should move the pointer back and forth between A and M. If not, then again, adjust the trims on your radio until they do. Once that is done then click finish and then write. At this point you should be able to disconnect and arm the motors.
sugs is offline        Reply With Quote
Old 05-24-2012, 12:57 AM   #6
helionfire
ok, i know i did everything right, so now fly time. arm the motors, give her some throttle, right side picks up and in a split second does a complete side rollover, all the motors are going in the proper direction, props on according to motor direction, now what up?
Old 05-24-2012, 01:07 AM   #7
petedee
You have something wrong, it is the only answer I can think of, if you have everything right it will just work.
DX18, 14SG
Old 05-24-2012, 01:51 AM   #8
sugs
I had the same problem when I first tried to maiden mine, would just flip right over. Turns out I had the motors off by one as you go around the X(I'm assuming you're in X configuration versus +) and I was sure I had them right.
Should look like this:
Front
m2 m1
. . X
m3 m4
Back
Odd motors turn counter-clockwise, even motors turn clockwise. Motor plugs on Naza controller must face forward, towards the front.
Old 05-24-2012, 02:31 AM   #9
helionfire
why do the motor plugs have to face forward? i have mine facing to the rear of the quad.
Old 05-24-2012, 02:33 AM   #10
helionfire
also, yes, x configuration, motor 1 and 3 cc 2 and 4 clockwise
Old 05-24-2012, 02:38 AM   #11
helionfire
ahhhh, gyro sensor??
Old 05-24-2012, 03:16 AM   #12
petedee
And there is your answer, motor connections must face the front.
Simple though and easy fix.
DX18, 14SG
Old 05-24-2012, 10:33 AM   #13
sugs
Yup, has to know which way is forward to react correctly, and for best results make sure it is as dead straight and as firmly mounted as you can get it.
Old 05-25-2012, 02:54 AM   #14
helionfire
ok, moved the naza so the motor inputs face forward, armed the motors, spun it up, all the motors going the right direction, then i shut her down, at this point its 3 in the morning in my garage with very little flight space.(im on afternoon shift so i dont get home till 1240 am), so im gonna leave my flight test till sat afternoon, i know she will fly right i would just rather wait until daylight. i will let you know how she flew. many, many thanks again to all
Old 05-25-2012, 03:57 AM   #15
petedee
Sounds like a good plan, good luck with your maiden, after that it will get much easier.
DX18, 14SG
Old 05-27-2012, 04:54 PM   #16
helionfire
ok, finally, saturday!! took my flamewheel to the backyard, armed the motors and up she went!! smooth as glass, what an incredible flyer although somewhat docile. neighbours looking as im flying asking me what the hell this thing is! very very nice quad, glad i sold my trex 250 to help fund this project. i may get rid of my fleet of helis because quads are so much more fun to fly. battery only lasted 6 min or so (3s 2200mah 20c) so i guess a stronger battery is next. i would definetly like to improve agility, especially on the rudder, how do i do this? also next up for me is a micro brushless quad, can anyone recommend one i can bind to my dx6i? about the same size as the blade mqx.
Old 05-27-2012, 05:09 PM   #17
sugs
Awesome, glad you got it up and flying.
Old 05-27-2012, 06:50 PM   #18
helionfire
special thanks to you sugs,
Old 05-27-2012, 06:52 PM   #19
helionfire
sorry, thanks to all that helped me
Old 05-28-2012, 12:24 AM   #20
petedee
I have some 1450kv motors that makes it move quicker, going to use them in a DJI330 frame.
I am not sure that there is a micro brushless that will bind to your DX6i, I do think that the Walkera Ladybird complete with a decent radio looked interesting, the radio will bind with other Walkera heli models as well.
DX18, 14SG
