| Outrage 550 Outrage 550 Helicopter Factory Support Forum |
Well..
No one seems to be interested in purchasing my frame + parts,,, so I am reviving it.. putting in torque servos.. and tx pack at 8v going fbl with it.. The velocity/fusion 50 FBL head is compatible I think right ?
Outrage 550, Goblin 630, 700, warp 360, Dual BL Mcpx, 130x **When you start to be in complete control reflexes are not a requirement.** |
The Fusion head is what everybody uses, you can also save a few bucks and use ds610's. Tons of people run them on 2s.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. AMA# 982814 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
do i need a different swash too ?
I forgot
You can use the 550 swash, but the fusion swash has improved geometry. You can get the f50 head and swash for $140 combined.
If money is an issue, I recently replaced the ds620s with Hyperion ds20x smd servos on the cyclic. They're less than $50. I've only had 100 flights on them, but I'm liking them so far. I think they hold better.
Sent from my Galaxy Nexus using Tapatalk 2 |
#6 |
Glad to see you are going to put your O550 back in the air. I have two of them flying at the moment and O550 #4 should be delivered today by the brown truck.
Paul Outrage 550 - Castle 3434-1100, Ice 100, Bec Pro, 94758z, Total G w/JR 8900G Outrage 550 - 4020-1390, Ice 100, Bec Pro, JR 8717s, Total G w/JR 8900G Rave Ballistic FSO - HKIII 4035-560, Ice HV160, Bec Pro, JR 8717s, Total G w/BL-9188 |
#7 |
hmmm
NO FUSION FBL heads are in stock. further more the individual parts are not all in stock either.. AARG I wonder if I can use my O550 feathering spindle and blade grips...
#8 |
Right here.
http://www.amainhobbies.com/product_...Conversion-Kit http://grandrc.com/p22028/R50N575-OU...duct_info.html
#9 |
If you buy the FBL swash make sure you buy the one with the anti-rotation pin. The Fusion 50 and new Velocity 50 N2 don't have one. Besides, the swash with the pin is $6.00 cheaper. Look in the O550 and Velocity 50 parts for it.
I have a bunch of FB heads and was thinking about using the blade grips and feathering shafts that I have as spares before replacing with the V50 grips etc when needed. I will have to check and see if the FBL arms will fit.
#10 |
i planned on removing the pin from my existing fb swash
#11 |
That might be a problem. The original swash is 2mm screws and the update ones are 2.5mm.
#12 |
oh great.. i dont know what swash i ordered lol.. need to look when it arrives
#13 |
My next order I was thinking about getting a Fusion elevator arm just for fun to see how it fits. Think it would be kinda cool to get rid of the anti-rotation bracket on my O550 if it works.
