Old 05-22-2012, 12:53 PM   #1
heli2012
Default Skookum SK-540 Setup on Align 450 v2 Pro
Hey Can I power Skookum SK-540 with the stock Align 450 pro esc (Align 35A Brushless ESC) Also can I use Governor with Hyperion Emeter2 Tachometer with the said esc.
Thank You.
heli2012 is offline        Reply With Quote
Old 05-22-2012, 01:22 PM   #2
Rollin_3z
Yes and yes..the bad thing is that the usb connector is on the back of the unit, so installing it on the top gyro plate blows. I have decided to keep my mini v on there and test it on my 400 logo
Gaui NX4 Trex 450 eFlite Mcpx BL
V Bar Pro
Rollin_3z is offline        Reply With Quote
Old 05-22-2012, 01:34 PM   #3
heli2012
I saw this is that what you are talking about, I want to install it just like the first part of that video.
Old 05-22-2012, 01:42 PM   #4
Rollin_3z
Yeah, you see how far back the unit is? Its over the boom now. It looks like a custom mount..not for me. You can also see how the servo wires go around the outside of the anti-rotation guide, so that his usb is facing on the outside. Look at your plate...its too short to have the unit that far out..
V Bar Pro
Old 05-22-2012, 01:52 PM   #5
heli2012
Ok got it, I guess inside the frame is too small, I should received this unit tomorrow, I order It from helidirect sunday. I had my 3gx mounted inside the frame.
Old 05-22-2012, 01:55 PM   #6
Rollin_3z
Here is a picture for reference. Half of the unit is sticking off plate. Skookum says you can mount it sideways on there, but it looks like kaka..
V Bar Pro
Old 05-22-2012, 01:58 PM   #7
Rollin_3z
You could mount it inside, but putting that usb cable might still be a bitch..let me know how it works out. I might try it inside too. What could be an option is to buy a small usb cable extension (Has male and female usb plugs) and leave it plugged in. I dont know where you could buy something like that. If you find a place, post up.
V Bar Pro
Old 05-22-2012, 02:08 PM   #8
heli2012
Do you think it can fit inside the frame on the base, if so can use a short usb extension. .http://www.angledcables.com/microb-extension.html
http://www.usbfirewire.com/uextendmicrob.html
Leave it connected to the unit for easy access, So you can put Spektrum DSMX Satellite Remote Receiver on top of the Anti rotation bracket.
Old 05-22-2012, 02:22 PM   #9
Rollin_3z
Perfect.. you're set. Thanks for the link.
V Bar Pro
Old 05-22-2012, 02:34 PM   #10
heli2012
You're welcome and thank you.
Old 05-22-2012, 05:29 PM   #11
mnc
I wanted mine inside the frame also but the sk 540 is to wide so I had to put it on top
ID:	318826   Click image for larger version
Trex 250 stock,Trex 450Pro,Trex 500 Sk 540,Trex 550
Compass Warp 360 MkS 92,Align 520, Skookum 540
Blade 300
Blade 130
mnc is offline        Reply With Quote
Old 05-22-2012, 06:36 PM   #12
5488fletcher
I made a aluminum plate that i contact cemented to the original anti rotation plate . I also used two rivets towards the front that are under the wires . It worked great .
ID:	318853   Click image for larger version
5488fletcher is online now        Reply With Quote
Old 05-22-2012, 07:39 PM   #13
Rollin_3z
Oh shit..It doesnt fit. Well, atleast others posted their setups. Thanks for that.
V Bar Pro
Old 05-22-2012, 08:00 PM   #14
heli2012
I know that really sucks, I will have to make an extension too, because that the only place you can fit it on a 450
Old 05-22-2012, 08:22 PM   #15
Icekold
Thanks 5488fletcher for posting your setup. I run SBUS as well and your photos help for me to complete my setup.
Icekold is offline        Reply With Quote
Old 05-25-2012, 09:07 AM   #16
heli2012
Hey what Head Gain and Tail Gain do you start at, I have Head Gain @ 60 and 50 and Tail Gain @ 60 and 70. Is this ok to spool up with.
Old 05-25-2012, 12:01 PM   #17
georgi UK
=] the SK locks in at a much lower value, 45% head 40% tail or less if using the SK gov, ballpark figures....
georgi UK
georgi UK is offline        Reply With Quote
Old 05-25-2012, 12:32 PM   #18
heli2012
Thank you I will try it and report back. Oh and how do I know when head gain is ok.
Old 05-25-2012, 01:09 PM   #19
Scallybert
Mine are fitted between the skids, inverted on the baseplate.
Seems to work fine.
Scallybert is offline        Reply With Quote
Old 05-25-2012, 01:29 PM   #20
georgi UK
=] the SK will make a 450 6x more stable than FB variants, it will feel solid and precise, locked in and predictable, it's not necessary to crank the gains up to achieve this!
georgi UK
