Go Back   HeliFreak > R/C Electronics Support > JLog - The JIVE logging stamp
JLog - The JIVE logging stamp JLog - The JIVE logging stamp - Official English Support Forum
Old 06-22-2012, 08:40 PM   #21
Rob43
Tom - did you mean to suggest that I change to a new SD card if I say, for example, change the motor?
= R
b43 =
Team Compass Support
Rob43 is offline        Reply With Quote
Old 06-23-2012, 02:11 AM   #22
Wynn1427
If you are going to leave the jLog mounted on one setup and just swap the motor just use the same card and create a new CONFIG.TXT file. I swapped the motor on mine and just added a ".old" behind the CONFIG.TXT filename (left it on the card still but shouldn't get read on startup). Fired up the jLog configurator and created a new CONFIG.TXT file with the current motor/gearing information. If your jLog device is jumping from setup to setup then its best to have a different card for each setup, that way you don't have to have a PC to write the correct CONFIG.TXT every time the jLog device moves to another setup.
Wynn
T-Rex 550 FBL
rcparts-finder.com...an online database to find your parts in stock at various online stores...
Wynn1427 is online now        Reply With Quote
Old 06-23-2012, 05:34 AM   #23
dl7uae
Wynn
Tom (http://JLog.hacknet.eu)
dl7uae is offline        Reply With Quote
