Old 05-23-2012, 09:14 AM   #1
Jamesppp
Default Setting Throttle Endpoints
I programmed my PowerJive 120hv to mode 1 then mode 4 then I tried to set the throttle enpoints on my Futaba Tx... Couldn't get it to arm.
My setup;
I have the BEC pin removed from the connector
Throttle Ch reversed (Futaba thing)
The receiver was powered with a nicd Rx pack
The 3 conductor wire w/BEC pin removed is plugged into the throttle channel
I used a 3S pack to plug into ESC ( could this be the prob?)
Throttle Ch endpoints set down around 50/50
Plugged the 3s packin with th stick low, advanced end point to max with no response from ESC
the 3s pack worked fine for mode 1 reset and mode 4 setup but I remember that CC HV controllers require a 4s battery , I think, to program .
Is there any obvious reason that this method would not work?
Can the jumper be stored on the ESC? If so does it have to be toward the center?
Thanks,
Jimmy
Compass7HV,Sk720HeliJive120HV Pyro 700 52L allHV
Outrage 550: Scorpion 4020-1390,CC125A ESC,WR ESC
Logo 5003D Scorpion Sk720 4020-1100, Blade130X MCPX
TT E-620 SE x 2: Scorpion 4025-740 200srx, nano qx JR Parkmites x 2
Jamesppp is offline        Reply With Quote
Old 05-23-2012, 09:23 AM   #2
DT75
Did you have th. endpoints at 100/100 when programming? If not, do so.
I think 3s should work. Jumper can be "stored" plugged in, which pins don't matter.
minicopter Diabolo, Henseleit TDR, X50e, X50n, Raptor 50
Futaba 2.4 GHz
DT75 is offline        Reply With Quote
Old 05-23-2012, 10:16 AM   #3
Jamesppp
Throttle endpoints were at 100/100 during programming and also have a linear, 0-100 throttle curve. Throttle hold is programmed but set to OFF during attempt to calibrate.
Thanks,
Jimmy
Old 05-23-2012, 10:20 AM   #4
dl7uae
Well..., 3S can be already one S too less for a HV JIVE..
Sorry: Objection, Your Honor. Use the labeled pins.
Tom
Tom (j-log.eu)
dl7uae is offline        Reply With Quote
Old 05-23-2012, 10:27 AM   #5
NRPY
Don't bother calibrating the TX endpoints. It doesn't really gain you anything, other than an ESC that won't arm.
NRPY is offline        Reply With Quote
Old 05-23-2012, 11:01 AM   #6
Jamesppp
Tom
Minimum 4s battery for the jive it is. I'll try it after work. I always go 3 or 4 past the point where it arms.
So leave the jumper plug on the pair of pins with arrows (towards the side of the case) or one arrow and the line towards the center of the case
Old 05-24-2012, 05:16 AM   #7
DT75
I stand corrected! At least I got one thing right...
Futaba 2.4 GHz
Old 05-24-2012, 10:46 AM   #8
Jamesppp
Thanks for the help!
jimmy
