| Mikado Logo 800 Xxtreme Mikado Logo 800 Xxtreme Helicopters Discussion |
Thanks to all who helped from HeliFreak during my build n set-up.
Maiden today : First impressions : Very Agile, Powerful, Stable, Smooth...Beautiful feeling... Issue : Only one quirk to sort out... When I do a 'Side Tick Tock', I get a slight twist in d heli, not really the tail not holding but heli doesnt hold straight in the air...? I dont know if its gain or CG...? holds fine in Rudder Flick, Pitch Pump n Upright Tick Tock... Anyone had this b4...? Suggestions...? Got a short Vid. Clip so u can c the tail move during the Side Tick Tock. Tks |
As I spool up its not so smooth, I did download the latest VBar n set Spool up rate to 3 as I had read it was an issue... Should i set it to 1 or 2. OR am I starting incorrectly. I set Normal Throttle curve to pt0/0-pt3/85-pt17/85. So when i flick off Throttle hold stick is at 0 then i slowly push the Thr.Stick up till it starts to spool up. Should I flick it to Idle.up then turn off Throttle hold to commence spool up...? would that give me the slow spool up rate I set in VBar...?
Tks |
I had the same problem the first time mine spooled up, if you look close at your video you can see the main blades twist a small amount throwing the balance off. I used a torque wrench and kept raiseing the torque till the blades did not twist, I ended up at 35 lbs in of torque. However I have noticed other videos that do not have such an sudden start-up like mine.
