| Synergy Model Helicopters Synergy Model Helicopters Support |
Hi Guys
I also posted this in the main room, hope you guys can help What is the best way to remove small e-rings? I find that I can remove them using a thin flat screwdriver but last time it took me awhile and was not effective. Is there a special tool for this? Here's the e-ring (circled) that I want to remove as I need to install a new washout link on my Synergy E7: ![]() |
I use a dental like pick to remove small e-clips.
http://www.harborfreight.com/4-piece...set-66836.html |
circlip pliers?
Rush 750 w/ Xera 4530-500 (12T), YGE160HV, WR S.BEC, Torq 9180/9188, AR7200BX Outrage 550 w/ Scorp 4020-1390 (13T), YGE120, CC BEC Pro, Quark, MKS BLS980, Futaba BLS451 Last Rebuild: 10/15/12 (O550) |
A big hammer, works every time.
Lynx Team Pilot GrandRC Field Rep BEASTX |
Helico-pteron to the rescue !
lol |
#6 |
I've been such a dick lately, I figured I'd help someone instead.
#7 |
I use a very small flat blade screwdriver tip to pry the circlip out.
#8 |
Probably the best way I know myself, but they do deform.
#9 |
What i usually do is use a flat bladed screw driver with a wide blade and use it to push the clip off the pin. If you use the wide part of the blade and then press on the open end of the clip to force the clip off the pin. Works and does'nt deform the clip so it can be reused.
Hope this helps, Ross
Thanks! Rossco |
