Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 500
Atom 500 Compass Atom 500 Model Helicopter Discussion
Old 05-25-2012, 12:34 AM   #1
Daniel880516
Default Atom 500 swashplate ball link snapped!
Hey guys, was doing some night flying today beside Square One's parking lot, luckily landed safely, apparently the swash plate ball link snapped when you can here the pop at around 4:15 minutes in the video, thank God was really close to ground and landed safely. So, do you guys think I should take the remaining screw inside the swash plate out and just put a ball link, or should I just get a new swash plate? As far as I can tell, I did size the delrin ball link a little bit on the loose side, do you think that might be the cause? I do have some play before when I hold the delrin tube and had a bit up and down play from the swash plate ball link. Thanks!
Team RotorQuest / SAB Heli Canada
Goblin 770
Xxtreme 800, Xxtreme 700
DX18
Daniel880516 is online now        Reply With Quote
Old 05-25-2012, 01:50 AM   #2
Daniel880516
Lol, i just realized that i have another 2 swash balls to use since i dont have any follower arms!
Goblin 770
DX18
Old 05-25-2012, 03:16 AM   #3
Daniel880516
Ok, just found out that my swash to pitch delrin ball link was hitting the outer swash plate side all the time with a 1.5 mm spacing that i was using, i can see some wear beside the delrin ball link, stock ball link without spacing was making the delrin ball link touching the inner swash plate. I found two 1mm spacers in the bag with some thin washers, fit it in and now its good.
Goblin 770
DX18
Old 05-25-2012, 10:08 AM   #4
Caleb White
Glad you got it fixed. Nice flight and pretty city lights, but be careful flying in cities like this... could have issues with law enforcement.
GUYS REMEMBER:
These balls should not be overtightened! This pre-loads the tiny threads, adding to the stress that can lead to shearing. Let the thread-lock do the work and just snug the balls up.
Check your interactions carefully. When I set up swash/FBL controller, I often spin the head by hand and move cyclic stick to corners. This will show me if links are in danger of hitting something and how bad the binding might be. (Usually it won't be that bad in the air though.)
As Daniel mentioned the plastic ball link to swash can hit the swash when the balls are spaced out. You want to be sure the links are adjusted to be straight on the ball and not side-ways. Then turn by hand and use radio to check before flight.
Compass Model | KBDD | MKS Servo | running Beast X and Airtronics
Caleb White is offline        Reply With Quote
Old 05-25-2012, 11:12 AM   #5
Daniel880516
GUYS REMEMBER:
+1 Thanks a lot Caleb! Understood and most likely wont do that again, was flying the unharmful night vapour, and just had the itch because the street lights was really bright lol.
Goblin 770
DX18
Old 05-25-2012, 02:44 PM   #6
Ah Clem
Well stated, Caleb!
KBDD-Team Pilot
Team Compass / ProStar Hobby
Gens Ace Field Representative
Warp 360, 7HV,Knight Pro,Knight 3D, Atom 500, Odin II, 6HV, 3D Plus, Knight 50
Old 05-25-2012, 03:17 PM   #7
John Cook
Location: Winnebago IL Where the politicians are MORE corrupt-Thanks alot Blago/Burris/Daley etc...
also, after crashes check these bolts as they can loosen up a bit and allow them to wiggle and fatigue
Team Alees
Scorpion Power Systems/Batteries
John Cook is offline        Reply With Quote
Old 05-25-2012, 03:28 PM   #8
Daniel880516
Thanks John Cook, I changed them with new bolts and mount them on the other 2 holes that weren't used, since I don't want to bother taking that piece out. Should be ok?
Goblin 770
DX18
Old 05-25-2012, 03:55 PM   #9
John Cook
should be I would think
Team Alees
Old 05-25-2012, 10:08 PM   #10
TheBum
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
I'd also suggest using red instead of blue loctite. On small threads, there's less for the loctite to grab onto, so red is warranted.
HeliFreak Support
Nankin Hobby Field Rep, Compass Support Team
Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX
Experience is something you obtain only after you need it.
TheBum is offline        Reply With Quote
Old 05-25-2012, 11:58 PM   #11
Trulsen
Just a note. Please refer to loctite number when you are suggesting like this. Red, if that is 222 you meen, that's not as good as 243 which is medium strength. And not, under any circumstances use loctite activator unless you really are in a hurry. That removes a lot of the strength from the loctite due to shorter curing time. :-)
- Futaba 14FG | TT Mini Titan V2 BeastX | Compass Warp 360BeastX | Logo 600 SX V-bar | Outrage Velocity 50N2 V-bar -
Trulsen is online now        Reply With Quote
Old 05-29-2012, 12:43 PM   #12
jchen
Alway replace the ball link on the derlin rod if there is play.
My came off while doing a roll over into inverted flight
jchen is online now        Reply With Quote
Old 06-03-2012, 05:34 AM   #13
Mostly
Hi
Does anyone know the part no and/or dimensions of this spacer washer that goes on the ball link connecting the swash to the delrin connector rods.
I thought they only gave a little extra leverage, seems they are essential.
I lost mine and can't see any references to them in the fbl instructions or the original manual.
Also do you use the same bolts when the spacer is added, obviously this means there is less thread available to go into the swash plate.
The size of the heads on the bolts that goes into links makes iw a little difficult to use normal bolts.
Mostly grateful
Mostly is offline        Reply With Quote
Old 06-03-2012, 06:36 AM   #14
Mostly
OK
The dimensionof the spacer is 3.5 OD x 1.9 ID x 1
I guess the bolt part number 80-0208s will take care of the extra distance.
The washer/spacer doesn't seem to have a part number so not sure how to get hold of one.
Mostly
Old 06-04-2012, 04:07 AM   #15
Mostly
Default Important bit
Found it in the end
The part no for the ball link spacer is 06-0404s
Mostly
Old 06-04-2012, 03:25 PM   #16
Daniel880516
Originally Posted by Mostly View Post
Found it in the end
Mostly
Do not use that spacer, that's for the servo to swash ball link, too thick for the pitch arm, but the screw of the bag is what I'm using just cut a little less than 1 mm off. The spacer should be around 1mm thick, just to clear the pitch ball link a bit from hitting the inside swash.
Goblin 770
DX18
Old 06-05-2012, 08:47 AM   #17
Mostly
I think I intended to say 06-0405s
This is what I think would do the job
Otherwise I will have to round off a 2 mm nut as described elsewhere.
I will get there eventually
Mostly very simple
Old 06-05-2012, 09:35 AM   #18
TheBum
I'm not sure why you'd need to round off the nut. Before I got the spacers from Mike at Nankin, I test fit a 2mm nut and had no rubbing issues.
That part number you cited is for the outer swash balls to reduce cyclic deflection. The spacers are too thick for the inner balls.
HeliFreak Support
Old 06-05-2012, 03:19 PM   #19
skinart76
I can't believe they still have not sourced those spacers out. These spacers are probably the most sought after part for the Atom. I had started inquiring about these when I first started building my Atom, 2 years ago! The spacers 06-0405s will work as that was all I can get my hands on. You still need to take a miniscule amout off of the link, you will be able to tell where once it is in place; but it was the best fit I can find. I had no ill effects when I had my Atom, it flew just fine.
skinart76 is offline        Reply With Quote
Old 06-06-2012, 02:33 PM   #20
Mostly
Default dIMINISHED my NUTS but back in the air
Thanks for all your help
I have checked with the nuts and I definitely need to take quite a bit off them for the mod to work, the swash would not rotate, with the nuts as are. In fact they lift the top of the swash. Maybe the newer versions have a more streamlined swash with less meat (ie cost).
Also I will need to grind the heads of some standard 8 mm bolts.
My thinking is that it would simplify everyones life if Compass did fastener kits for each model.
Anyway can't complain too much the heli is shit hot, so I guess they know their onions.
Mostly grateful
