Go Back   HeliFreak > R/C Helicopters > Aerodynamics, Physics and Engineering
Aerodynamics, Physics and Engineering Aerodynamics, Physics and Engineering Discussions
Old 05-26-2012, 02:06 AM   #1
Martin353
Default Blade lift
Is it possible to work out the extra lift gained (or lost) from different sized blades if running at the same hs? i.e what % extra lift would you get from changing from a 550 size to a 600 size blade.
I am here: http://tapatalk.com/map.php?0pdghl
I'd rather be flying than typing
Martin353 is offline        Reply With Quote
Old 05-26-2012, 02:17 PM   #2
Martin353
I'm kinda guessing that be a no then lol
I am here: http://tapatalk.com/map.php?lbotvo
Old 05-26-2012, 02:50 PM   #3
TowPilot
You could use a small bucket with weights that you add until it can't be lifted.
Change blades, go through the process again to see the difference of vertical lift.
This doesn't account for how a blade will perform during forward flight during maneuvers though.
TowPilot is online now        Reply With Quote
Old 05-26-2012, 06:36 PM   #4
npomeroy
Hang in there. I don't think many are viewing this forum yet.
There will be a simple calculation for the theoretical lift increase, and I think it will be significant as much of the lift comes from the outer end ofthe blade.
Nelson JR DSX9 II; Stretched Atom 500 in Bell 222 body , TRex550 in Funkey/Century Jet Ranger. Stretched TRex550 in 600 size AS350 - . SK720 all round. Trex 450 S for sport practice. MCP-X.
npomeroy is online now        Reply With Quote
Old 05-26-2012, 07:47 PM   #5
TowPilot
And there is going to be a cost, and increased drag for increased lift. The calculation will also probably show, the additional power needed, to generate increased lift. Just a guess.
Old 05-26-2012, 11:06 PM   #6
extrapilot
There is no simple calculation; most of the parameters that define lift are undefined here. Easiest option is to throw the machine on a scale, and run it up in negative pitch 550 vs 600 blades, and see the delta.
Just based on blade theory, by my calcs, the 53” dia rotor will generate approx 55% more thrust than the 47” dia rotor at a given non-stalled AOI/RPM. Best to measure- the calcs dont account for important variables.
"The problem with quotes found on the internet is you have no way of confirming their authenticity." - Abraham Lincoln
extrapilot is online now        Reply With Quote
Old 05-26-2012, 11:36 PM   #7
npomeroy
Just based on blade theory, by my calcs, the 53 dia rotor will generate approx 55% more thrust than the 47 dia rotor at a given non-stalled AOI/RPM. Best to measure- the calcs dont account for important variables.
I hoped you would contribute to this one extrapilot.
Do you not agree that in the way the OP phrased the question there is an assumption of "all other things being equal" e.g. HS and blade design; so shouldn't these cancel out and allow a genuinely useful calculation?
Old 05-27-2012, 06:13 AM   #8
Martin353
Hi all.
Thanks for the replies. The question was asked assuming everything else remained the same. I.e same pinion, motor, batts etc and just changing the blades.
Some interesting points made tho. Where do u get thus info from? I've looked on google but can't find anything.
I am here: http://tapatalk.com/map.php?bu2d3z
Old 05-27-2012, 10:17 AM   #9
YoungBull
Bear in mind I've had a few drinks and a noob. Extrapilot sounds ontrack.
Could you (ignoring all other parameters, motor, headspeed) posibly measure by blade pitch?
eg: throttle hold at 2000rpm head speed. Set max throw at +1, then +2, then +3 ect ect, until lift has occured -place tape on skids that break at 1kg of force - test with kitchen scales
550 blade surface area(a) / 600 blade surface area (b)
Pitch req for a and b. eg: a = 3deg, b = 2deg
diff of 1 deg ( remebering head speed and motor not inc)
The increased surface area of b req 1 deg less pitch = 50% lift increase.
Almost impossible calc as any % will change through full collective range, fwd flight, ect.
Or maybe this link could help
http://www.ehow.com/how_7680704_calc...or-blades.html
450 se, 450 v2, using Jr 2610.
550e 3GX , Dx7, 1 sat. RF6, Redback LiPo's.
600efl Pro, 3GX, bec, Castle HV80, 2 sats.
YoungBull is offline        Reply With Quote
Old 05-29-2012, 04:47 PM   #10
jmmccain
Simply? Yes. Accurately? Don't know.
In this thread I posted a number of equations for lift, drag, torque, and power. They are all nothing more than very simple integrals. I know the three for drag, torque, and power work quite well for both models and full scale. The one for lift probably works well too, but I don't know what range of coefficient to plug into it (lack of data).
Joseph (too many folks want to call me Jim )
Like that lucky old sun, give me nothin' to do, but roll around heaven all day.
jmmccain is offline        Reply With Quote
