Old 05-26-2012, 11:24 AM   #1
Lompma
Question Where to mount Beastx unit on Plastic kit
Just wondering where people are mounting their FBL units on the plastic kits. It does not look like the right angle under the bearing blocks. I was thinking the bottom of the boom block to protect it from blade strikes. I had to sand it a little to get it flat. Any suggestions?
Mini Protos 4S, Logo 480 Stretch, Logo 400SE
Protos Max V2, Synergy E5, Goblin 570 12S
Lompma is offline        Reply With Quote
Old 05-26-2012, 11:40 AM   #2
My98stang46
Mine isn't the plastic but I put mine in the "traditional" gyro location.
Prôtos 500CF FBL Vbar
Blade 450FBL Tarot ZYX
2003 SVT Cobra 538RWHP
2010 Corvette ZR1 all stock
Blade 450FBL, PRTOS 500CF FBL
My98stang46 is offline        Reply With Quote
Old 05-26-2012, 12:09 PM   #3
banditpowdercoat
Top of boom block in the traditional position
Dan Pesonen
FBL, Don't think about it, DO IT.
mCX2, nCPX, mCP X, Blade 400, MSH PRTOS, T-700N
"Tri-Flow"
I put that S*** on everything!"
banditpowdercoat is offline        Reply With Quote
Old 05-26-2012, 12:13 PM   #4
Mr dan
Top of boom block is where I mounted mine.
Mr dan is offline        Reply With Quote
Old 05-26-2012, 01:14 PM   #5
Lompma
Did anyone sand it flat. I took a metal carpenter square to it and it has quite a hump in the middle.
Old 05-26-2012, 02:12 PM   #6
alexf1852
What I did was cut the mounting tape (3M gray) into two narrow strips and put them on each side of the hump so that the bottom of the BeastX does not touch the hump. You might need two layers.
MSH Protos * 2, SAB 630, Logo 550SX
alexf1852 is offline        Reply With Quote
Old 05-26-2012, 02:40 PM   #7
Mikej
I have mine under the main shaft - I made up a 2.5 degree wedge to make it flat
Mikej is online now        Reply With Quote
Old 05-26-2012, 04:00 PM   #8
DaveGahan
Hi !
I have mine mounted on the traditional gyro plattform, too. It works really fine this way !
Greetings,
Oliver
Prtos 500 - Scorpion 3026-880kv, YGE 60, Savx 1250/1290. BeastX, AR7000
7HV - Pyro 700-52, Heli Jive 120HV, Savx 1258TG, BLS251, AR7200BX
DaveGahan is offline        Reply With Quote
Old 05-26-2012, 04:40 PM   #9
sjaaktrekhaak
I recently had a bad crash and if i would have had the beastx under the main shaft it would have been destroyed completely due to the main shaft penetrating through the beast.
Just a heads up
Sent from my phone
T Rex 700 E V-Bar Silverline
T Rex 600 ESP - V-Bar
MSH - Protos 500 - BeastX
Blade - Mcpx
sjaaktrekhaak is offline        Reply With Quote
Old 05-26-2012, 04:42 PM   #10
Mikej
Thanks - I know it's a risk - but this is a $30 Copterx that is in an aluminium case so hopefully safe and if not it is at least cheap
Old 05-26-2012, 04:51 PM   #11
DaveGahan
I have been thinking about getting a sk720 or sk540 since a while now.
Skookum advises to install it somewhere around cg. That's why I'm not sure about it...
I have the "same problem" with the LOGOs. Perhaps I would go for one but in these birds the battery is installed under the main shaft and could easyly destroyed in case of a crash...
I would go for the traditional place.
Greetings,
Oliver
Old 05-27-2012, 08:54 PM   #12
desertstalker
Greetings,
Oliver
The SK720 will work perfectly on the boom block (it does on my mini) the CoG advise is because vibrations are lower there but the protos design has low vibrations anyway (unlike a TT with transmission gears under the tail block). If you ignore vibrations you can mount the unit pretty much anywhere, as long as you can get it perpendicular to the mainshaft, neither rotational velocity or linear acceleration are altered by position on a rigid body (which the heli is to all intents).
The 540 can be mounted anywhere, it has negligible vibration sensitivity
-DX8
Old 12-29-2012, 11:19 PM   #13
matthewcornell
I did this but a crash that required a boom change caused me to rethink this location because splitting the block required removing the AR7200BX :-( I had moved it to the slanted portion under the boom, but I'm thinking a slant is bad for the BX. And I see someone created an angled mounting adapter to keep it horizontal below the main gear. Thoughts?
matthewcornell is offline        Reply With Quote
Old 12-29-2012, 11:27 PM   #14
banditpowdercoat
You don;t have to split the cases for a boom change. Remove bolts and block slides out. I've done it with BX in place. Amd yes if you mount on the lower flat under the main shaft you NEED a angle to make the BX exactly perpendicular to the mainshaft
Dan Pesonen
"Tri-Flow"
Old 12-29-2012, 11:51 PM   #15
matthewcornell
Thanks, but I'm confused about how to get the boom out without separating the two halves. There is a round pin/extrusion inside one (both?) half that keeps the boom in place.
Old 12-30-2012, 12:13 AM   #16
solex227
Talking
Ut-OH read this thread on the which end is which...
http://www.helifreak.com/showthread.php?t=461526
Solex227
solex227 is offline        Reply With Quote
Old 12-30-2012, 12:19 AM   #17
crickr1
Need to mount gyros/fbl. In traditional location on boom. Frame geometry of plastic kit is not 90* to main shaft. For cf frame there is optional upgrade lower frame section.
As far as splitting boom support for boom change, the hole is at tail box and slot is at boom block. Loosen 4 bolts and 2 screws to slide boom out. You can mount fbl unit on bottom of boom block. To help in blade strike. My fbl brains are mounted under boom.
Prtos 380Prtos 470, Max V2- 14s!
"CHRONOS" ,OXY3+Qube,4s/Tareq 6s,
Diabolo 550/Triabolo800 Goblin660 "TDRII"
MSH-Brain Jeti DS16
OXY rep/Lynx team pilot
ctzn526
crickr1 is offline        Reply With Quote
Old 12-30-2012, 12:52 AM   #18
matthewcornell
That explains it! Note that the manual is dead wrong (see attached pic), as discussed in the very helpfully-linked to thread. Guess it is time to take her apart again. It will be nice to try flying it someday :-|
Old 12-30-2012, 02:12 AM   #19
solex227
Im with you! I have yet to fly my own but im waiting on batts and charger. You will get there and youre in the right place for information. Just stick with it ....
Solex227
Old 01-01-2013, 06:49 PM   #20
1157
My BeastX has been on the inside of the frame of my plastic kit for over a year and it flies great.
Stu
1157 is offline        Reply With Quote
